@usmannasir @CyberPanel I’m facing Error 503 when try to access cyberpanel admin, work fine for all frontend website only cann’t login into lwcp and cyberpanel admin
Anyone faced like me?
Thank you
Thank you
Did you change MySQL password?
Did you change MySQL password?Not
See gunicorn status
systemctl status gunicorn.socket
If it is not working, then start
systemctl start gunicorn.socket
See gunicorn statussystemctl status gunicorn.socket
Thank you @usmannasir
Then, when I activated ModSecurity, my over all disk about +40GB fully. May you give me solution with my wrong
Thank you
Disable SecAuditEngine: https://docs.cyberpanel.net/doku.php?id=modsecurity-configurations
Thank you, lets me try because currently turn off ModSecurity feature now
Disable SecAuditEngine: https://docs.cyberpanel.net/doku.php?id=modsecurity-configurationsThank you, lets me try because currently turn off ModSecurity feature now
You can keep ModSecurity on, just disable audit logging so it won’t generate extensive logs.
Ok, thank you
@usmannasir any suggestion to get autologin into phpmyadmin from panel? just like cPanel
Tq
That can go into feature request section.
