After installing Cyberpanel I can not access, it gives the message of ERR_CONNECTION_CLOSED.
I opened port 8090 and the error remains
CyberPanel opens all the default required ports on installation.
You may want to check with your provider.
Provider is ok, this is some Cyberpanel error
Provider is Vultr
Submit a ticket, I will have a look.
Same here, my vultr vps, i alway got that proplem! Please help!. I hate that
Provider is ok, this is some Cyberpanel errorProvider is Vultr
you solved your problem??
Did you try a different browser/private window?
