The error log is attached
ct 20 02:57:07 egit-group.org sudo[4182]: root : TTY=unknown ; PWD=/tmp/lscpd ; USER=root ; COMMAND=/bin/cat /etc/postfix/main.cf
Oct 20 02:57:11 egit-group.org postfix[4194]: Postfix is running with backwards-compatible default settings
Oct 20 02:57:11 egit-group.org postfix[4194]: See http://www.postfix.org/COMPATIBILITY_README.html for details
Oct 20 02:57:11 egit-group.org postfix[4194]: To disable backwards compatibility use “postconf compatibility_level=2” and “postfix reload”
Oct 20 02:57:11 egit-group.org postfix[4194]: /usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_sender_restrictions
Oct 20 02:57:11 egit-group.org postfix[4194]: /usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_client_restrictions
Oct 20 02:57:11 egit-group.org postfix[4194]: /usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_helo_restrictions
Oct 20 02:57:11 egit-group.org postfix[4194]: /usr/sbin/postconf: warning: /etc/postfix/main.cf: undefined parameter: virtual_mailbox_limit_maps
Oct 20 02:57:11 egit-group.org postfix[4194]: /usr/sbin/postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_create_maildirsize=yes
Oct 20 02:57:11 egit-group.org postfix[4194]: /usr/sbin/postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_maildir_extended=yes
Oct 20 02:57:11 egit-group.org postfix/postfix-script[4200]: stopping the Postfix mail system
Oct 20 02:57:11 egit-group.org postfix/master[2598]: terminating on signal 15
Oct 20 02:57:11 egit-group.org aliasesdb[4203]: /usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_sender_restrictions
Oct 20 02:57:11 egit-group.org aliasesdb[4203]: /usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_client_restrictions
Oct 20 02:57:11 egit-group.org aliasesdb[4203]: /usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_helo_restrictions
Oct 20 02:57:11 egit-group.org aliasesdb[4203]: /usr/sbin/postconf: warning: /etc/postfix/main.cf: undefined parameter: virtual_mailbox_limit_maps
Oct 20 02:57:11 egit-group.org aliasesdb[4203]: /usr/sbin/postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_create_maildirsize=yes
Oct 20 02:57:11 egit-group.org aliasesdb[4203]: /usr/sbin/postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_maildir_extended=yes
Oct 20 02:57:11 egit-group.org postfix[4208]: Postfix is running with backwards-compatible default settings
Oct 20 02:57:11 egit-group.org postfix[4208]: See http://www.postfix.org/COMPATIBILITY_README.html for details
Oct 20 02:57:11 egit-group.org postfix[4208]: To disable backwards compatibility use “postconf compatibility_level=2” and “postfix reload”
Oct 20 02:57:11 egit-group.org postfix[4208]: /usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_sender_restrictions
Oct 20 02:57:11 egit-group.org postfix[4208]: /usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_client_restrictions
Oct 20 02:57:11 egit-group.org postfix[4208]: /usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_helo_restrictions
Oct 20 02:57:11 egit-group.org postfix[4208]: /usr/sbin/postconf: warning: /etc/postfix/main.cf: undefined parameter: virtual_mailbox_limit_maps
Oct 20 02:57:11 egit-group.org postfix[4208]: /usr/sbin/postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_create_maildirsize=yes
Oct 20 02:57:11 egit-group.org postfix[4208]: /usr/sbin/postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_maildir_extended=yes
Oct 20 02:57:11 egit-group.org postfix/postfix-script[4272]: starting the Postfix mail system
Oct 20 02:57:11 egit-group.org postfix/master[4274]: daemon started – version 3.4.7, configuration /etc/postfix
Oct 20 02:57:12 egit-group.org postfix/qmgr[4276]: 06C2140B71: from=[email protected], size=8329, nrcpt=1 (queue active)
Oct 20 02:57:12 egit-group.org postfix/qmgr[4276]: 305A840B6F: from=[email protected], size=4555, nrcpt=1 (queue active)
Oct 20 02:57:12 egit-group.org postfix/qmgr[4276]: 7457F40B6E: from=[email protected], size=5825, nrcpt=1 (queue active)
Oct 20 02:57:12 egit-group.org postfix/pipe[4277]: fatal: get_service_attr: unknown username: spamd
Oct 20 02:57:12 egit-group.org postfix/pipe[4278]: fatal: get_service_attr: unknown username: spamd
Oct 20 02:57:12 egit-group.org postfix/pipe[4279]: fatal: get_service_attr: unknown username: spamd
Oct 20 02:57:13 egit-group.org postfix/qmgr[4276]: warning: private/spamassassin socket: malformed response
Oct 20 02:57:13 egit-group.org postfix/qmgr[4276]: warning: transport spamassassin failure – see a previous warning/fatal/panic logfile record for the problem description
Oct 20 02:57:13 egit-group.org postfix/master[4274]: warning: process /usr/libexec/postfix/pipe pid 4277 exit status 1
Oct 20 02:57:13 egit-group.org postfix/master[4274]: warning: /usr/libexec/postfix/pipe: bad command startup – throttling
Oct 20 02:57:13 egit-group.org postfix/master[4274]: warning: process /usr/libexec/postfix/pipe pid 4278 exit status 1
Oct 20 02:57:13 egit-group.org postfix/master[4274]: warning: process /usr/libexec/postfix/pipe pid 4279 exit status 1
Oct 20 02:57:13 egit-group.org postfix/error[4280]: 06C2140B71: to=[email protected], relay=none, delay=353, delays=352/1/0/0.04, dsn=4.3.0, status=deferred (unknown mail transport error)
Oct 20 02:57:13 egit-group.org postfix/error[4282]: 305A840B6F: to=[email protected], relay=none, delay=1138, delays=1137/1.1/0/0.03, dsn=4.3.0, status=deferred (unknown mail transport error)
Oct 20 02:57:13 egit-group.org postfix/error[4283]: 7457F40B6E: to=[email protected], relay=none, delay=543, delays=542/1.1/0/0.01, dsn=4.3.0, status=deferred (unknown mail transport error)
Oct 20 03:00:01 egit-group.org CROND[4313]: (root) CMD (/usr/local/CyberCP/postfixSenderPolicy/client.py hourlyCleanup)
Oct 20 03:00:01 egit-group.org postfix/pickup[4275]: B1DDF40B73: uid=0 from=
Oct 20 03:00:01 egit-group.org postfix/cleanup[4326]: B1DDF40B73: message-id=[email protected]
Oct 20 03:00:01 egit-group.org postfix/qmgr[4276]: B1DDF40B73: from=[email protected], size=867, nrcpt=1 (queue active)
Oct 20 03:00:01 egit-group.org postfix/pipe[4334]: B1DDF40B73: to=[email protected], orig_to=, relay=dovecot, delay=0.29, delays=0.19/0.01/0/0.09, dsn=5.1.1, status=bounced (user unknown. Command output: lda([email protected]): Error: net_connect_unix(/var/run/dovecot/stats-writer) failed: Permission denied )
Oct 20 03:00:01 egit-group.org postfix/cleanup[4326]: DD7FD40B74: message-id=[email protected]
Oct 20 03:00:01 egit-group.org postfix/qmgr[4276]: DD7FD40B74: from=<>, size=3285, nrcpt=1 (queue active)
Oct 20 03:00:01 egit-group.org postfix/bounce[4338]: B1DDF40B73: sender non-delivery notification: DD7FD40B74
Oct 20 03:00:01 egit-group.org postfix/qmgr[4276]: B1DDF40B73: removed
Oct 20 03:00:01 egit-group.org postfix/pipe[4334]: DD7FD40B74: to=[email protected], relay=dovecot, delay=0.04, delays=0.01/0/0/0.03, dsn=5.1.1, status=bounced (user unknown. Command output: lda([email protected]): Error: net_connect_unix(/var/run/dovecot/stats-writer) failed: Permission denied )
Oct 20 03:00:01 egit-group.org postfix/qmgr[4276]: DD7FD40B74: removed
Oct 20 03:04:30 egit-group.org postfix/smtpd[4498]: connect from unknown[45.148.10.187]
Oct 20 03:04:32 egit-group.org postfix/smtpd[4498]: warning: unknown[45.148.10.187]: SASL LOGIN authentication failed: Invalid authentication mechanism
Oct 20 03:04:33 egit-group.org postfix/smtpd[4498]: disconnect from unknown[45.148.10.187] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Oct 20 03:04:58 egit-group.org postfix/pickup[4275]: 92BD94129A: uid=5002 from=
Oct 20 03:04:58 egit-group.org postfix/cleanup[4572]: 92BD94129A: message-id=[email protected]
Oct 20 03:04:58 egit-group.org postfix/qmgr[4276]: 92BD94129A: from=[email protected], size=868, nrcpt=1 (queue active)
Oct 20 03:04:58 egit-group.org postfix/smtp[4580]: connect to gmail-smtp-in.l.google.com[2a00:1450:4013:c04::1b]:25: Network is unreachable
Oct 20 03:04:59 egit-group.org postfix/smtp[4580]: 92BD94129A: to=[email protected], relay=gmail-smtp-in.l.google.com[173.194.69.27]:25, delay=0.64, delays=0.18/0.03/0.21/0.22, dsn=2.0.0, status=sent (250 2.0.0 OK 1571533499 s19si1330933edd.351 - gsmtp)
Oct 20 03:04:59 egit-group.org postfix/qmgr[4276]: 92BD94129A: removed
Oct 20 03:05:07 egit-group.org postfix/pickup[4275]: 2D9164129A: uid=0 from=
Oct 20 03:05:07 egit-group.org postfix/cleanup[4572]: 2D9164129A: message-id=[email protected]
Oct 20 03:05:07 egit-group.org postfix/qmgr[4276]: 2D9164129A: from=[email protected], size=570, nrcpt=1 (queue active)
Oct 20 03:05:07 egit-group.org postfix/pipe[4623]: 2D9164129A: to=[email protected], orig_to=, relay=dovecot, delay=0.12, delays=0.06/0.01/0/0.06, dsn=5.1.1, status=bounced (user unknown. Command output: lda([email protected]): Error: net_connect_unix(/var/run/dovecot/stats-writer) failed: Permission denied )
Oct 20 03:05:07 egit-group.org postfix/cleanup[4572]: 4B26A4129B: message-id=[email protected]
Oct 20 03:05:07 egit-group.org postfix/qmgr[4276]: 4B26A4129B: from=<>, size=2988, nrcpt=1 (queue active)
Oct 20 03:05:07 egit-group.org postfix/bounce[4627]: 2D9164129A: sender non-delivery notification: 4B26A4129B
Oct 20 03:05:07 egit-group.org postfix/qmgr[4276]: 2D9164129A: removed
Oct 20 03:05:07 egit-group.org postfix/pipe[4623]: 4B26A4129B: to=[email protected], relay=dovecot, delay=0.03, delays=0.01/0/0/0.03, dsn=5.1.1, status=bounced (user unknown. Command output: lda([email protected]): Error: net_connect_unix(/var/run/dovecot/stats-writer) failed: Permission denied )
Oct 20 03:05:07 egit-group.org postfix/qmgr[4276]: 4B26A4129B: removed
Oct 20 03:07:12 egit-group.org postfix/qmgr[4276]: 06C2140B71: from=[email protected], size=8329, nrcpt=1 (queue active)
Oct 20 03:07:12 egit-group.org postfix/qmgr[4276]: 9D42C40B6B: from=[email protected], size=4550, nrcpt=1 (queue active)
Oct 20 03:07:12 egit-group.org postfix/qmgr[4276]: 7457F40B6E: from=[email protected], size=5825, nrcpt=1 (queue active)
