i cannot able to send any emails from snappy mail…i checked port 25 its opened
cannot able to share my email log file getting new user cannot post more than 2 links error
Checking givingcommunity.tech from www12-do.checktls(.)com(V03.72.03) at 2023-10-01T22:28:47Z:
seconds | lookup | result | |
[000.000] | DNS LOOKUPS | ||
[000.010] | SEARCHLIST | 104.131.108.216,134.209.169.224,1.1.1.1,8.8.8.8,67.207.67.3 | |
[000.054] | MX | (10) mail.givingcommunity.tech | |
[000.067] | MX:A–>mail.givingcommunity.tech | 37.128.204.223 |
seconds | test stage and result | |
[000.000] | Trying TLS on mail.givingcommunity.tech[37.128.204.223:25] (10) | |
[000.140] | Server answered | |
[000.772] | <‑‑ | 220 givingcommunity.tech ESMTP Postfix |
[000.773] | We are allowed to connect | |
[000.773] | ‑‑> | EHLO www12-do.checktls(.)com |
[000.911] | <‑‑ | 250-givingcommunity.tech |
250-PIPELINING | ||
250-SIZE 30720000 | ||
250-ETRN | ||
250-STARTTLS | ||
250-AUTH PLAIN | ||
250-AUTH=PLAIN | ||
250-ENHANCEDSTATUSCODES | ||
250-8BITMIME | ||
250-DSN | ||
250 CHUNKING | ||
[000.911] | We can use this server | |
[000.912] | TLS is an option on this server | |
[000.912] | ‑‑> | STARTTLS |
[001.054] | <‑‑ | 220 2.0.0 Ready to start TLS |
[001.054] | STARTTLS command works on this server | |
[001.222] | Connection converted to SSL | |
SSLVersion in use: TLSv1_3 | ||
Cipher in use: TLS_AES_256_GCM_SHA384 | ||
Perfect Forward Secrecy: yes | ||
Session Algorithm in use: Curve X25519 DHE(253 bits) | ||
Certificate #1 of 1 (sent by MX): | ||
Cert VALIDATION ERROR(S): self signed certificate | ||
So email is encrypted but the recipient domain is not verified | ||
Cert Hostname VERIFIED (mail.givingcommunity.tech = mail.givingcommunity.tech) | ||
Not Valid Before: Oct 1 02:05:04 2023 GMT | ||
Not Valid After: Sep 28 02:05:04 2033 GMT | ||
subject: /C=US/ST=Denial/L=Springfield/O=Dis/CN=mail.givingcommunity.tech | ||
issuer: /C=US/ST=Denial/L=Springfield/O=Dis/CN=mail.givingcommunity.tech | ||
[001.226] | ~~> | EHLO www12-do.checktls(.)com |
[001.520] | <~~ | 250-givingcommunity.tech |
250-PIPELINING | ||
250-ETRN | ||
250-AUTH PLAIN | ||
250-AUTH=PLAIN | ||
250-8BITMIME | ||
250-DSN | ||
250 CHUNKING | ||
[001.521] | TLS successfully started on this server | |
[001.521] | ~~> | MAIL FROM:<test@checktls(.)com> |
[001.683] | <~~ | 250 2.1.0 Ok |
[001.684] | Sender is OK | |
[001.684] | ~~> | QUIT |
[001.828] | <~~ | 221 2.0.0 Bye |
check mail log file added (.) this instead of . so it wont be considered as a link.coz getting new user cannot post more than 2 link error
Oct 1 21:45:48 server postfix/cleanup[195800]: C770887B7C: message-id=<10c0afaa6c7d17b2b43225458eb99bfb21617a3f@givingcommunity(.)tech>
Oct 1 21:45:48 server opendkim[13778]: C770887B7C: DKIM-Signature field added (s=default, d=givingcommunity(.)tech)
Oct 1 21:45:48 server postfix/qmgr[195069]: C770887B7C: from=<info@givingcommunity(.)tech>, size=1073, nrcpt=1 (queue active)
Oct 1 21:45:48 server postfix/submission/smtpd[195796]: disconnect from localhost[::1] ehlo=2 starttls=1 auth=1 mail=1 rcpt=1 data=1 quit=1 commands=8
Oct 1 21:45:48 server dovecot: imap([email protected])<195795>: Disconnected: Logged out in=852 out=579 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct 1 21:45:55 server dovecot: imap-login: Login: user=<info@givingcommunity(.)tech>, method=PLAIN, rip=::1, lip=::1, mpid=195805, TLS, session=
Oct 1 21:45:55 server dovecot: imap([email protected])<195805>: Disconnected: Logged out in=119 out=967 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct 1 21:46:19 server postfix/smtp[195803]: connect to in.mail.tm[49.12.18.190]:25: Connection timed out
Oct 1 21:46:19 server postfix/smtp[195803]: connect to in.mail.tm[2a01:4f8:c011:4d4::1]:25: Network is unreachable
Oct 1 21:46:19 server postfix/smtp[195803]: C770887B7C: to=<jnvmka@diginey(.)com>, relay=none, delay=31, delays=0.12/0.03/30/0, dsn=4.4.1, status=deferred (connect to in.mail.tm[2a01:4f8:c011:4d4::1]:25: Network is unreachable)
Oct 1 21:47:36 server postfix/smtpd[195839]: connect from keeper-us-east-1d.mxtoolbox(.)com[18.209.86.113]
Oct 1 21:47:37 server postfix/smtpd[195839]: NOQUEUE: reject: RCPT from keeper-us-east-1d.mxtoolbox(.)com[18.209.86.113]: 554 5.7.1 <test@mxtoolboxsmtpdiag(.)com>: Relay access denied; from=<supertool@mxtoolboxsmtpdiag(.)com> to=<test@mxtoolboxsmtpdiag(.)com> proto=ESMTP helo=<keeper-us-east-1d.mxtoolbox(.)com>
Oct 1 21:47:37 server postfix/smtpd[195839]: using backwards-compatible default setting smtpd_relay_before_recipient_restrictions=no to reject recipient “test@mxtoolboxsmtpdiag(.)com” from client “keeper-us-east-1d.mxtoolbox(.)com[18.209.86.113]”
Oct 1 21:47:37 server postfix/smtpd[195839]: disconnect from keeper-us-east-1d.mxtoolbox(.)com[18.209.86.113] ehlo=1 mail=1 rcpt=0/1 quit=1 commands=3/4
Oct 1 21:50:02 server dovecot: imap-login: Login: user=<info@givingcommunity(.)tech>, method=PLAIN, rip=::1, lip=::1, mpid=195886, TLS, session=
Oct 1 21:50:02 server dovecot: imap([email protected])<195886>: Disconnected: Logged out in=105 out=960 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct 1 21:50:02 server dovecot: imap-login: Login: user=<info@givingcommunity(.)tech>, method=PLAIN, rip=::1, lip=::1, mpid=195887, TLS, session=
Oct 1 21:50:02 server dovecot: imap([email protected])<195887>: Disconnected: Logged out in=89 out=641 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct 1 21:50:57 server postfix/anvil[195798]: statistics: max connection rate 1/60s for (submission:::1) at Oct 1 21:45:48
Oct 1 21:50:57 server postfix/anvil[195798]: statistics: max connection count 1 for (submission:::1) at Oct 1 21:45:48
Oct 1 21:50:57 server postfix/anvil[195798]: statistics: max cache size 1 at Oct 1 21:45:48
Oct 1 21:54:02 server postfix/qmgr[195069]: 56A2487B46: from=<info@givingcommunity(.)tech>, size=1090, nrcpt=1 (queue active)
Oct 1 21:54:02 server postfix/qmgr[195069]: C770887B7C: from=<info@givingcommunity(.)tech>, size=1073, nrcpt=1 (queue active)
Oct 1 21:54:32 server postfix/smtp[195986]: connect to mail.protonmail.ch[176.119.200.128]:25: Connection timed out
Oct 1 21:54:32 server postfix/smtp[195987]: connect to in.mail.tm[49.12.18.190]:25: Connection timed out
Oct 1 21:54:32 server postfix/smtp[195987]: connect to in.mail.tm[2a01:4f8:c011:4d4::1]:25: Network is unreachable
Oct 1 21:54:32 server postfix/smtp[195987]: C770887B7C: to=<jnvmka@diginey(.)com>, relay=none, delay=524, delays=494/0.03/30/0, dsn=4.4.1, status=deferred (connect to in.mail.tm[2a01:4f8:c011:4d4::1]:25: Network is unreachable)
Oct 1 21:55:02 server postfix/smtp[195986]: connect to mail.protonmail.ch[185.70.42.128]:25: Connection timed out
Oct 1 21:55:32 server postfix/smtp[195986]: connect to mail.protonmail.ch[185.205.70.128]:25: Connection timed out
Oct 1 21:56:02 server postfix/smtp[195986]: connect to mailsec.protonmail.ch[185.70.42.129]:25: Connection timed out
Oct 1 21:56:32 server postfix/smtp[195986]: connect to mailsec.protonmail.ch[185.205.70.129]:25: Connection timed out
Oct 1 21:56:32 server postfix/smtp[195986]: 56A2487B46: to=<givingcommunity@proton(.)me>, relay=none, delay=65291, delays=65141/0.04/150/0, dsn=4.4.1, status=deferred (connect to mailsec.protonmail.ch[185.205.70.129]:25: Connection timed out)
Oct 1 22:02:25 server dovecot: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=167.94.138.127, lip=37.128.204.223, session=
Oct 1 22:02:27 server dovecot: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 1 secs): user=<>, rip=167.94.138.127, lip=37.128.204.223, session=
Oct 1 22:02:27 server dovecot: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=167.94.138.127, lip=37.128.204.223, session=
Oct 1 22:02:28 server dovecot: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=167.94.138.127, lip=37.128.204.223, session=
Oct 1 22:02:29 server dovecot: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=167.94.138.127, lip=37.128.204.223, session=<1bhP0K4GLOqnXop/>
Oct 1 22:02:29 server dovecot: pop3-login: Disconnected: Disconnected: Too many bad commands (no auth attempts in 0 secs): user=<>, rip=167.94.138.127, lip=37.128.204.223, session=<rK5T0K4G+qynXop/>
Oct 1 22:04:02 server postfix/qmgr[195069]: C770887B7C: from=<info@givingcommunity(.)tech>, size=1073, nrcpt=1 (queue active)
Oct 1 22:04:32 server postfix/smtp[196209]: connect to in.mail.tm[49.12.18.190]:25: Connection timed out
Oct 1 22:04:32 server postfix/smtp[196209]: connect to in.mail.tm[2a01:4f8:c011:4d4::1]:25: Network is unreachable
Oct 1 22:04:32 server postfix/smtp[196209]: C770887B7C: to=<jnvmka@diginey(.)com>, relay=none, delay=1124, delays=1093/0.05/30/0, dsn=4.4.1, status=deferred (connect to in.mail.tm[2a01:4f8:c011:4d4::1]:25: Network is unreachable)
Oct 1 22:05:03 server dovecot: imap-login: Login: user=<info@givingcommunity(.)tech>, method=PLAIN, rip=::1, lip=::1, mpid=196234, TLS, session=
Oct 1 22:05:03 server dovecot: imap([email protected])<196234>: Disconnected: Logged out in=105 out=968 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct 1 22:05:03 server dovecot: imap-login: Login: user=<info@givingcommunity(.)tech>, method=PLAIN, rip=::1, lip=::1, mpid=196235, TLS, session=
Oct 1 22:05:03 server dovecot: imap([email protected])<196235>: Disconnected: Logged out in=329 out=1067 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
email logs same i have added (.) instead of . coz new user cannot paste more than 2 links error
