crazy92
February 23, 2022, 10:43pm
#1
After send and email from yahoo or gmail the user recive this error:
This is the mail system at host mfz.ro.
I’m sorry to have to inform you that your message could not
be delivered to one or more recipients. It’s attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
<–@mfz.ro > (expanded from <–>): bad address syntax
<-@mfz.ro > (expanded from <->): bad address syntax
<-f@mfz.ro > (expanded from <-f>): bad address syntax
<contact@mfz.rocontactpipe >: Host or domain name not found. Name service error
for name=mfz.rocontactpipe type=AAAA: Host not found
crazy92
February 23, 2022, 10:44pm
#2
i recive the mail at xxxx@mfz.ro but the user still recive this error
do you send it from a php script ?
do you send it with SMTP ?
do you send it from rainloop ?
it depends where you send it from what could cause the error
and based on above errors it seems you need to check your postfix config , as the 3 above emails are not emails but looks like commands that get converted to emails instead
Greetings from PowerChaos
crazy92
February 24, 2022, 10:09am
#4
This is the email that i recive when i send a email from a gmail account or yahoo
you need to check your postfix config file , seems there is a error in that file as the above are flags that are not suposed to be forwarded/procecced
Hi crazy92, did you manage to solve the problem?
I’m having the same issue. I know why it happened as it is related with a bad configuration of the pipe program, but I don’t know how to solve it.
