Great, so far so good.
Great to hear!
Per Rainloop’s recommendation, I added escaping of special characters to the variables that are in the SQL statements (not present in their custom SQL password plug-in, but a good thing to have for security’s sake, nonetheless). With that now knocked out, they should hopefully approve it soon and commit it to their main repo.
Thank you !! Worked!!
Hello again friends,
As directed by the indicated commands, unfortunately the correction is not possible, according to the executed commands and answers below:
1st OPTION
[root@vmi208383 ~]# yum remove yum-plugin-priorities -y
Loaded plugins: fastestmirror
File contains parsing errors: file:///etc/yum.repos.d/dovecot.repo
[line 2]: name=Dovecot 2.3 CentOS 7 - x86_64
[line 3]: baseurl=http://repo.dovecot.org/ce-2.3-latest/centos/7/RPMS/x86_64
[line 4]: gpgkey=https://repo.dovecot.org/DOVECOT-REPO-GPG
[line 5]: gpgcheck=1
[line 6]: enabled=1
[root@vmi208383 ~]#
2nd OPTION
[root@vmi208383 ~]# /etc/yum/pluginconf.d/priorities.conf
-bash: /etc/yum/pluginconf.d/priorities.conf: No such file or directory
[root@vmi208383 ~]#
NOTE: Even now when trying to update the OS is in error.
[root @ vmi208383 ~] # yum update
File contains parsing errors: file: ///etc/yum.repos.d/dovecot.repo
[line 2]: name = Dovecot 2.3 CentOS 7 - x86_64
[line 3]: baseurl = http: //repo.dovecot.org/ce-2.3-latest/centos/7/RPMS/x86_64
[line 4]: gpgkey = https: //repo.dovecot.org/DOVECOT-REPO-GPG
[line 5]: gpgcheck = 1
[line 6]: enabled = 1
What steps to take?
Remove this file /etc/yum.repos.d/dovecot.repo and try again.
Enjoy your accelerated Internet by CyberPanel & OpenLiteSpeed
[root@vmi208383 ~]# /etc/yum.repos.d/dovecot.repo
-bash: /etc/yum.repos.d/dovecot.repo: Permission denied
[root@vmi208383 ~]#
The lines 2-6 in /etc/yum.repos.d/dovecot.repo are indented. Just remove the spaces in front of them using a editor like vim, nano etc so that it looks like this: Screenshot 2019-08-02 at 15...
Save the file, and run yum update again.
[root@vmi208383 ~]# yum apt-get install nano
No such command: apt-get. Please use /usr/bin/yum --help
[root@vmi208383 ~]#
There is no apt-get on CentOS.
yum install nano should do the trick, but with the corrupted repo file it will not work anyway. You can use vi though.
George, thanks for your help, but even as directed by the command line: yum install nano, does the error persist, so if not abuse, have I given you more guidance?
The mistake below when I entered the command
[root @ vmi208383 ~] # yum install nano
You can remove this file /etc/yum.repos.d/dovecot.repo
Friends, I greatly appreciate the support to solve this problem, but unfortunately I am not succeeding, following the command above presents the error below:
[root@vmi208383 ~]#
Please, what procedure to do?
Use rm command to remove the file
rm /etc/yum.repos.d/dovecot.repo
Hello
Im using Ubuntu and cant Login into Rainloop I cant use this command
