Hi, I have the same issue. When following the suggested Link, I am receiving following errors:
File “manage.py”, line 22, in
File “/usr/lib64/python2.7/site-packages/django/core/management/init.py”, line 363, in execute_from_command_line
utility.execute()
File “/usr/lib64/python2.7/site-packages/django/core/management/init.py”, line 355, in execute
File “/usr/lib64/python2.7/site-packages/django/core/management/base.py”, line 283, in run_from_argv
File “/usr/lib64/python2.7/site-packages/django/core/management/base.py”, line 327, in execute
self.check()
File “/usr/lib64/python2.7/site-packages/django/core/management/base.py”, line 359, in check
include_deployment_checks=include_deployment_checks,
File “/usr/lib64/python2.7/site-packages/django/core/management/base.py”, line 346, in _run_checks
return checks.run_checks(**kwargs)
File “/usr/lib64/python2.7/site-packages/django/core/checks/registry.py”, line 81, in run_checks
new_errors = check(app_configs=app_configs)
File “/usr/lib64/python2.7/site-packages/django/core/checks/urls.py”, line 16, in check_url_config
return check_resolver(resolver)
File “/usr/lib64/python2.7/site-packages/django/core/checks/urls.py”, line 26, in check_resolver
return check_method()
File “/usr/lib64/python2.7/site-packages/django/urls/resolvers.py”, line 254, in check
for pattern in self.url_patterns:
File “/usr/lib64/python2.7/site-packages/django/utils/functional.py”, line 35, in get
File “/usr/lib64/python2.7/site-packages/django/urls/resolvers.py”, line 405, in url_patterns
patterns = getattr(self.urlconf_module, “urlpatterns”, self.urlconf_module)
File “/usr/lib64/python2.7/site-packages/django/urls/resolvers.py”, line 398, in urlconf_module
return import_module(self.urlconf_name)
File “/usr/lib64/python2.7/importlib/init.py”, line 37, in import_module
import(name)
File “/usr/local/CyberCP/CyberCP/urls.py”, line 43, in
url(r’^docker/’, include(‘dockerManager.urls’)),
File “/usr/lib64/python2.7/site-packages/django/conf/urls/init.py”, line 50, in include
urlconf_module = import_module(urlconf_module)
import(name)
File “/usr/local/CyberCP/dockerManager/urls.py”, line 2, in
import views
File “/usr/local/CyberCP/dockerManager/views.py”, line 7, in
from .container import ContainerManager
File “/usr/local/CyberCP/dockerManager/container.py”, line 22, in
import docker
ImportError: No module named docker
[moneke@vmd32972 CyberCP]$ python manage.py migrate
utility.execute()
self.check()
File “/usr/lib64/python2.7/site-packages/django/core/management/commands/migrate.py”, line 62, in _run_checks
issues.extend(super(Command, self)._run_checks(**kwargs))
import(name)
import(name)
import views
import docker
So thanks in advance for any help!
