Evening all,
I appreciate there’s a feature request in place and the developers are looking into / adding the feature but has anyone managed to get a working ‘catch all’ email solution in place (in the mean time / temporary solution until a CyberPanel feature is added) within the CyberPanel configuration?
I’ve followed a few guides and have tried to mash it together with the CyberPanel installation but i’m getting nowhere unfortunately.
Currently i’ve created a catch all table, e_catchall
with the structure and data like -
| id | source | destination | enabled |
| 1 | @example1.com | admin@example1.com | 0 |
| 2 | @example2.com | admin@example1.com | 1 |
| 3 | @example3.com | admin@example1.com | 1 |
And then have a Postfix config, mysql-virtual_catchall.cf
file as follows -
`user = USERNAME
password = PASSWORD
dbname = cyberpanel
query = SELECT destination FROM e_catchall WHERE source = CONCAT('@','%d') AND enabled = 1
hosts = localhost`
- used ‘%d’ as i found ‘%s’ would usually pull in the full email address rather than just the domain; although i have noticed ‘%d’ sometimes equals the senders domain (??).
And i’ve changed the alias maps line within main.cf
to -
`virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_catchall.cf, mysql:/etc/postfix/mysql-virtual_forwardings.cf, mysql:/etc/postfix/mysql-virtual_email2email.cf`
In theory, certainly in my head, this should work but Postfix is throwing 554 5.7.1 Relay access denied;
errors.
I’ve attached a link to a Pastebin of the full main.cf
(not standard, used on other production servers) in case it helps but does anyone have a reason why my implementation doesn’t work or have a proper/better solution that works?
This is about the only thing that’s stopping me using CyberPanel properly on my productions servers so any help will be greatly appreciated!
main.cf
- https://pastebin.com/jDm0svdX
