how can we do this on litespeed
<VirtualHost *:8080>
ProxyPass “/” “http://localhost:9200/”
ProxyPassReverse “/” “http://localhost:9200/”
</VirtualHost
</VirtualHost
Here’s how to do:
tried that and it doesnt works as
curl -i http://localhost:8080/_cluster/health doesnt works
added the redirect under Rewrite Rules but not working
It works for sure. I have 8 domains that work as a reverse proxy. Read carefully what needs to be done. You redirect a non-standard port to work on a standard domain, i.e. on the server it runs on port xxxx but you have access as domain.ltd.
See Method 3: Proxying with Rewrite Rules. Very versatile and works like a charm.
https://openlitespeed.org/kb/reverse-proxy-basics/#Method_3_Proxying_with_Rewrite_Rules_The_most_versatile_way_to_proxy_and_the_simplest_for_name-based_virtual_hosting
