Dynamic response body size is over the limit
When i download database may be 40-50 MB i get this error in DB
The dynamic response body size is over the limit, the response will be truncated by the web server. The limit is set in the key 'maxDynRespSize' located in the tuning section of the server configuration, and labeled 'max dynamic response body size'.
Max Request URL Length (bytes) 32768
Max Request Header Size (bytes) 65530
Max Request Body Size (bytes) 10M
Max Dynamic Response Header Size (bytes) 62768
Max Dynamic Response Body Size (bytes) 512M
This is the config i have
what should i change here, 2 GB ram ?
