If I go to “Manage” the domain for domain a.com and I make an “Alias Domain” b.com I always get redirected to https://a.com when trying to view https://b.com
I also use ISPConfig, and when I use a domain alias there, and if I would go to https://b.com I would see a.com, but b.com would be in my browsers address bar. When I try this with cyberpanel it always redirects to a.com.
Is this how cyberpanel behaves when using domain aliases? Because if that is the case you could use simple redirects as well. I don’t think that this is the right behaviour for this function.
The idea of a Domain Alias is really that you can type b.com in your browser bar, and see a.com.
I found a way to do this. In the DNS I made an A record for the domain pointing it to the IP address of the server. That didn’t work. But when I make a CNAME for b.com pointing to a.com it works good.
This way you can pretend to have many many websites, while making only 1…
If you need domain aliasing, it’s much easier to “Add Domains” instead of using “Aliases”. Simply define ‘public_html’ as the document root, and it will work as you are expecting. That is especially useful if you need SSL certificates for your domains, as this will generate independant SSL certificates for any added domains.
