I want to install CyberPanel on OpenLiteSpeed with 4 GB RAM server.
However, I always see a limit of only 2047 MB in the control panel.
Is CyberPanel limited memory?
2GB ram limit is on CyberPanel Ent (for free starter package), with OpenLiteSpeed there is no limit and its free.
I want to install CyberPanel on OpenLiteSpeed with 4 GB RAM server. However, I always see a limit of only 2047 MB in the control panel. Is CyberPanel limited memory?
may be you choose Litespeed enterprise ! its 2GB limit … reinstall with Openlitespeed its no limit Ram
I installed OpenLiteSpeed on CentOS 7, then installed CyberPanel. However, I always see a limit of 2047 MB, I tried changing it to 4096 MB (my server RAM 4 GB) and restarting. After restarting, it returns to 2047 MB!
So what?
I want to install CyberPanel on OpenLiteSpeed with 4 GB RAM server. However, I always see a limit of only 2047 MB in the control panel. Is CyberPanel limited memory?may be you choose Litespeed enterprise ! its 2GB limit … reinstall with Openlitespeed its no limit Ram
I use OpenLiteSpeed, I installed according to the documentation on Get OpenLiteSpeed!. So I can’t install LiteSpeed instead of installing OpenLiteSpeed!
You don’t need to install OpenLiteSpeed before installing CyberPanel, it will be installed. Just follow this guide Installing CyberPanel - CyberPanel
You don't need to install OpenLiteSpeed before installing CyberPanel, it will be installed. Just follow this guide https://cyberpanel.net/docs/installing-cyberpanel/
The default when installing CyberPanel will install OpenLiteSpeed at the same time?
You don't need to install OpenLiteSpeed before installing CyberPanel, it will be installed. Just follow this guide https://cyberpanel.net/docs/installing-cyberpanel/The default when installing CyberPanel will install OpenLiteSpeed at the same time?
Yes
Do I understand correctly that if I install OpenLiteSpeed without CyberPanel memory is unlimited. However, if I install CyberPanel then the provided OpenLiteSpeed is limited to 2GB ?
Please read this page Installing CyberPanel - CyberPanel
In short, if you use CyberPanel w/OpenLiteSpeed there are no limits on the ram. Limits are only applied when you use LiteSpeed Ent.
so is there a cpu limit? I have a 2 core processor but it shows 1 in top processes.
