Docker and CSF Problems
Got to know about this issue from client server.
If anyone on CyberPanel is using Docker and they have also installed CSF. Then I am experiencing various problems.
I’ve installed csf and enabled docker support in csf configurations.
Then I created docker app from CyberPanel, but keep getting 503 error. It turns out that if i remove csf, remove and re-install docker then apps start working.
I’ve seen couple of posts on reddit, stackoverflow having similar problems.
If you want to remove and re-install Docker, read this guide: Debugging Docker Apps Features – Knowledge Base
This is a devloping story as I’ve contacted csf support…
Update 1: It seems that after adding port 8088 to csf docker apps seems to be working.
But in some cases they are still not working as expected.
Update 2:
If I create Docker App, then install CSF, it does not work.
I had to delete docker and re-install docker from cli and start it again.
Then make sure port 8088 and port 5678 is in CSF for TCP_IN and TCP_OUT.
Then created docker app again and it works.
