I think it’s a good panel option, I installed the panel in a minimal 7 centos, everything was installed correctly, but when entering the administration panel gives us the following error.
This site can not be accessed
It took too long to respond. .
I contacted server support and gave us this answer
It appears that your container is setup with a custom software which caused the container to be missing many system components, I advise you in this case to backup your data in Recovery mode and Restore the server cleanly or you can try to resolve this issue in Recovery mode, to view your files and filesystem you will need to type the command chroot /mnt.
Provider: server4you
Virtualization Type: Virtuozzo
System: Centos 7 minimal
Installation option: since during the installation.
there will be few option to choose,so please provide it as well.
OLS or Enterprise?
OLS
official
Mirror server network is optimized for Asia Pacific region…
If you experience very slow download speed during installation, please try use mirror server on clean system…
Use mirror server [y/N]: y
This may improve panel loading speed in Asia Pacific region…
Please select [y/N]: y
Install LiteSpeed Memcached?
Install Redis?
Problem:
It is installed normally but does not enter the control panel. Already install 2 times and the error mentioned above is not exceeded
