I have Created my Private Name server vs1.fastjobupdate.in and point it to my server ip
Also created dns+nameservers in cyberpanel
When i open my website erorr
DNS_PROBE_FINISHED_NXDOMAIN
IT seems dns are not propagated or set properly which domain provider you are using
i cant see the ip of this domain
Thanks for reply
private Nameservers change
https://drive.google.com/file/d/1AiDUOKLRxtk1ykUisQcR1LChil6MVG4a/view?usp=drivesdk
A record in DNS Settings (cyberpanel)
https://drive.google.com/file/d/1ApJvnWuKhOZfNu1LcGrxbvKNmi0gFZ1W/view?usp=drivesdk
At your registrar, where you pointed your domain to your nameservers, specify also the nameservers IP, instead of just the domain.
Without providing the IP as well (glue records), it can’t find itself.
That only works if you are not hosting the nameservers yourself, because you are, you need to specify the nameserver IP.
Please explain More
Sent message.
It’s easier to show you by anydesk
my page has had the same problem for 2 days.
Computers with a VPN can log in. I tried 8.8.8.8 dns inide did not help.
I couldn’t find a solution
