Hello…How can I fix the problem with dkim? It’s all ok but it’s not active.
Can you show results from here ? Test Email Score - CyberPanel on Cloud
It gives me these 2 errors in the check I do here. https://www.skysnag.com/blog/what-is-a-dkim-record/
Please fix DKIM using this: Achieve 10/10 Email score with CyberPanel!
The connection is not working. ![]()
https://cyberpanel.net/2018/01/28/how-to-setup-spf-dkim-and-dmarc-inside-cyberpanel-manually/
I am fixing the problem.!!! What I did is I downloaded a new dkim from here DKIM Record Generator | EasyDMARC
