Dear Sir !
What about info to login this…
https://x.x.x.x:8090/admin
Thanks
Dear Sir !
Thanks
are you asking for > https://x.x.x.x:8090/admin
to be in cyberpanel or needing help with loggin in?
Hi Jack !
I know the info for login to manage cyberpanel https://x.x.x.x:8090 , but i have seen some DOORs can effect with the security as: https://x.x.x.x:8090/rainloop/?admin, https://x.x.x.x:8090/admin, …the info to login to rainloop is ok i know it is default, but the second i don’t know and i don’t know what is that…and i don’t know there are any other …DOORs that i don’t know ?..
Thanks
PS: I see this pannel is so good if the admin can fix some thing : security, doors, …and this pannel is run depend on the website https://code.angularjs.org/, if this website die, the pannel die too…
what is the default login for Rainloop Admin - admin & 12345 but that does not work ?
You need to use this link for rainloop administrator login: https://:8090/rainloop/?admin
