Hello everyone.
Firstly I’m a beginner using VPS with Linux.
I chose Cyberpanel because of its ease of setup and usability. It’s really very good!
But this time I found a problem that I can not solve.
I have around 10 sites installed on my VPS (Vultr 20USD) and noticed that there was suddenly a huge increase in disk usage.
Looking for the problem (with my technical limitations), I found something that caught my attention.
I have a / tmp / folder that is consuming 55GB, I do not know what its exactly is, however it seems a bit out of the ordinary.
Could anyone help me identify what may have caused this huge increase in disk usage and how can I prevent this from happening again?
Thanks in advance for any help.
Thank you.
What is the output of ls -la /tmp
Also, try to find out which files and folders are using more space in /tmp.
I have the same problem. I only have one website, it consumes nearly 500mb but my disk space is 90/100 of 17gb. I delete all my backups by using ftp but nothing changed. I restart my server, I still have the problem. How can I solve the problem? should I delete tmp files, where are they? Sorry I am a beginner, please tell me as simple you can. thank you.
@fadosolrelamisi
What is the output of df -h
I am waiting your help, thank you.
This page gives 403 error on my end
403 Forbidden
nginx
I can see that your root mount point is only 17GB and it is indeed 97% full.
I Have same problem. My space will full.
How to clean the temp / trash file in cyberpanel…?
franko
October 17, 2019, 8:35am
11
I had similar problem with full disk.
Error log was spamming every second.
I have a solution to your problem
set log only 1 day
Hi guys, in Cyberpanel, OLS web admin panel looks pretty concise, and this advantage can be integrated into CyberPanel. Some advanced configuration needs to be done in OLS webadmin console. including how to stop log, You can fix the error to...
set log only 1 day
https://pc-mind.com/how-to-disable-huge-log-openlitespeed-cyberpanel/
Not working to me…well I can’t find the screen to modify 30 days log to 1
I run command of delete “find /usr/local/lsws/logs/ -name ‘log.2 ’ -delete”
Server when run → df -h → https://i.hizliresim.com/49R1RJ.png
Any kind of hunt to solve this? (100gb and just 20% free)
Thanks
@fadosolrelamisi @CyberPanel
Any solution for the same issue
