Is there a way to disable TLSv1, as I have as an issue when checking my website. It is an e-commerce and it seems that I have to disable it in order to be PCI compliant?
Thanks.
Thanks.
Go to https://your-server-ip:7080
Then Listeners / SSL / View / SSL, Tick TLS 1.2 & 1.3
Thank you. Worked like charm.
