Hi Guys!
I’m into CP for about a week but already lov it. Before I was operating on Virtualmin but here all goes much quicker!
Even tho I am not familiar with programming or server administration (rather shops administration), all seems to be very friendly for users like me.
So … I have installed prestashop 1.6 for testing purpose and all runs smoothly and super quick, and CP does everything what is really needed apart of one issue which I discovered in error logs.
I’ve got this notice:
PHP Fatal error: require_once(): Failed opening required ‘/home/domain.com/public_html/modules/modules/search/…/…/config/config.inc.php’ (include_path=’.:/usr/local/lsws/lsphp70/share/pear:/usr/local/lsws/lsphp70/share/php:/usr/share/pear:/usr/share/php’) in /home/domain.com/public_html/modules/modules/search/search_ajax.php on line 27
so lets go deeper → line 27 of php script states:
require_once(dirname(FILE).’/…/…/config/config.inc.php’);
Correct path for above mentioned file is /home/domain.com/public_html/config/config.inc.php
While I was reading php documentation, this seems to be correct execution ( dirname(FILE) is where the script file itself is included) but somehow on my old Apache path was interpreted correctly, have any of you can direct me what should I do to make it work?
Maybe I have to set some additional handlers, I dont know - here is my lack of skills …sorry
Ps. I know that I could go around in the file but the thing is that this should work, so maybe some enviroment issue exists ?
my setup:
CP 1.8.3
OLS 1.4.46
PHP 7.0.33
PHP Handler LiteSpeed SAPI
Cache ON
Anyone has idea?
