I removed cmstest2.newstargeted.com from CyberPanel (Connected to Cloudflare)
But it does not remove the subdomain totally.
The folder for the subdomain is automatically created by CyberPanel, but no indication on CyberPanel of it’s existence, other than the error in the log.
Perhaps remove or let this button inside the main domain do the same?
I would like to delete it from the main domain instead of having to list all sub-domains on it’s own list.
I’m normally just inside the main domain, and the full subdomain list is there.
Sadly if you delete it from here now, it removes the domain and continues to create the folder, and SSL every day with errors on SSL cannot be created.
