an
Hi
I changed the default port of CP and now there is no access to my CP
I cheek this : /etc/ssh/sshd_config but there is no information on this file ! jus few line was uncomment
Would someone please tell me how to fix that?
Thanks
Hi
Thanks
Login to SSH and then enter this command:
sudo systemctl stop firewalld
And then try cyberpanel login
After you are able to access cyberpanel, add your new port number to firewall whitelist. Never change port number without adding it in firewall first.
