am I able to host a site with dedicated ip(another additional IP of the server) other than default one (main IP).?
If i am not mistaken it is possible from litespeed web console.
are you able to guide me to do that ?
I assume you already have access to openlitespeed web console if not i suggest you to enable port 7080 from firewall settings in your cyberpanel after that login to your web console with user name admin and your webconsole password(default is 123456) after that head over to listeners, you have to create two listeners for the specific ip you want with port 80 and port 443 after creating the listener you just have to map the virtualhost to both listeners and its all you need.
Thanks, I will try adding listeners
