ahrovan
1
Hello
- openlitespeed cyberpanel installed on ubuntu.
- List Databases > Select Domain > Remote Access > Manage > Allow Remote Access on following IP > Save Changes
- But it is not possible to connect to the database from the specified ip.
https://www.yougetsignal.com/ says:
Port 3306 is closed on specified ip
How can I solve the problem?
Nada
2
Please open the port into your firewall, check both internal configurations and if your provider firewall enabled
ahrovan
3
Command 'ufw' not found
do i need to install ufw?
Nada
4
I don’t know but I still think it’s just firewall block please share screenshot which would help too
