Website setup with php 7.3 and post_max_size = 800M also setup but not able to upload the database of 26mb
Always display
500
Internal Server Error
need support to host the new site
Always display
Please anyone for it
Changing default settings of PHP works for your website but not for phpMyAdmin which is why you’re still unable to upload database. there is a way to increase upload size for phpMyAdmin. But, I suggest you upload .sql file in root directory of your website and use shell to upload your database like this:
sudo mysql -u database_username -p database_name < /home/domain.tld/database_file.sql
Example: sudo mysql -u mysite_db -p mysite_db < /home/mysite.com/sql_backup2022.sql
when you enter this command it will ask for a password, enter password of same database user you put in the command.
