Provider: Contaba
Virtualization Type: VPS
System: Centos 8
Installation option: CyberPanel
OLS or Enterprise?
OLS
official
yes
Install LiteSpeed Memcached?
yes
Install Memcached?
yes
yes
Install Redis?
yes
Problem:
I have already MariaDB 10.5.x installed on Centos 8 and get the following error when I try to install CyberPanel 2.0.3. My understanding is that this should work with MariaDB 10.5.x.
Error:
Problem: package mariadb-devel-3:10.3.17-1.module_el8.1.0+257+48736ea6.x86_64 requires mariadb-connector-c-devel >= 3.0, but none of the providers can be installed
- package mariadb-connector-c-devel-3.0.7-1.el8.i686 requires libmariadb.so.3, but none of the providers can be installed
- package mariadb-connector-c-devel-3.0.7-1.el8.x86_64 requires mariadb-connector-c = 3.0.7-1.el8, but none of the providers can be installed
- package MariaDB-shared-10.5.3-1.el8.x86_64 obsoletes mariadb-connector-c provided by mariadb-connector-c-3.0.7-1.el8.i686
- package MariaDB-shared-10.5.3-1.el8.x86_64 obsoletes mariadb-connector-c provided by mariadb-connector-c-3.0.7-1.el8.x86_64
- problem with installed package MariaDB-shared-10.5.5-1.el8.x86_64
- package MariaDB-shared-10.5.4-1.el8.x86_64 obsoletes mariadb-connector-c provided by mariadb-connector-c-3.0.7-1.el8.i686
- package MariaDB-shared-10.5.4-1.el8.x86_64 obsoletes mariadb-connector-c provided by mariadb-connector-c-3.0.7-1.el8.x86_64
- conflicting requests
- package MariaDB-shared-10.5.5-1.el8.x86_64 obsoletes mariadb-connector-c provided by mariadb-connector-c-3.0.7-1.el8.i686
- package MariaDB-shared-10.5.5-1.el8.x86_64 obsoletes mariadb-connector-c provided by mariadb-connector-c-3.0.7-1.el8.x86_64
- installed package MariaDB-shared-10.5.5-1.el8.x86_64 obsoletes mariadb-connector-c provided by mariadb-connector-c-3.0.7-1.el8.i686
- installed package MariaDB-shared-10.5.5-1.el8.x86_64 obsoletes mariadb-connector-c provided by mariadb-connector-c-3.0.7-1.el8.x86_64
(try to add ‘–skip-broken’ to skip uninstallable packages or ‘–nobest’ to use not only best candidate packages)
command failed, exiting…
