When trying to run the cyberpanel_utility command from console I’m receiving the following error:
/usr/bin/cyberpanel_utility: line 31: Debug_Log2: command not found
Any ideas?
Thank you.
Any ideas?
Thank you.
Has anybody read this post from devs? Thank you.
Hello @Mick
Thank you for waiting and sorry for no reply.
Run the command
wget -O /usr/bin/cyberpanel_utility https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/cyberpanel_utility.sh
Thanks @josephgodwinke
I followed your instructions (as root) and received the following (as root):
Currently running the following:
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.2 LTS
Release: 22.04
Codename: jammy
Thank you.
There is an issue in the script as it does not acually detect ubuntu 22 versions. Can you run this instead
wget -O /usr/bin/cyberpanel_utility https://raw.githubusercontent.com/josephgodwinkimani/cyberpanel-mods/main/cyberpanel_utility.sh
now try running the script
Thank you very much for trying to help so quickly @josephgodwinke , I am receiving the following however:
KIndly try again I fixed how os is detected. Wget the same file and run it
@josephgodwinke Still the same I’m afraid. It looks like it’s auto-updating when I run it? Maybe from original source instead of yours?
OK seen hwere the issue is. Try now
Thank you, sorted.
