Cyberpanel + ubuntu 20.04 +CSF Error Not working
Hi there after installing cyberpanel and MODSECURITY. when i visit page ‘‘security - firewall’’ i receive this error ‘’
Error The path to iptables is either not set or incorrect for IPTABLES [/sbin/iptables] in /etc/csf/csf.conf at /usr/local/csf/lib/ConfigServer/URLGet.pm line 26. Compilation failed in require at /usr/local/csf/lib/ConfigServer/DisplayUI.pm line 20. BEGIN failed–compilation aborted at /usr/local/csf/lib/ConfigServer/DisplayUI.pm line 20. Compilation failed in require at /usr/local/csf/bin/cyberpanel.pl line 14. BEGIN failed–compilation aborted at /usr/local/csf/bin/cyberpanel.pl line 14.
and this message visiting ‘Security & Firewall Plugins’’
I have this error
My System is Ubuntu 20.04
I Changed vi /etc/csf/csf.conf
To
IPTABLES = “/usr/sbin/iptables”
IPTABLES_SAVE = “/usr/sbin/iptables-save”
IPTABLES_RESTORE = “/usr/sbin/iptables-restore”
IP6TABLES = “/usr/sbin/ip6tables”
IP6TABLES_SAVE = “/usr/sbin/ip6tables-save”
IP6TABLES_RESTORE = “/usr/sbin/ip6tables-restore”
And still the problem exist !
When i excute: sudo csf -r
I recieve this error
Error Setting IPTABLES is repeated in /etc/csf/csf.conf - you must remove the duplicates and then restart csf and lfd at /usr/local/csf/lib/ConfigServer/URLGet.pm line 26.
Compilation failed in require at /usr/sbin/csf line 21.
BEGIN failed–compilation aborted at /usr/sbin/csf line 21.
or
systemctl status lfd.service
● lfd.service - ConfigServer Firewall & Security - lfd
Loaded: loaded (/usr/lib/systemd/system/lfd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2022-05-26 15:55:39 BST; 18s ago
Process: 18778 ExecStart=/usr/sbin/lfd (code=exited, status=255/EXCEPTION)
May 26 15:55:39 ***** systemd[1]: Starting ConfigServer Firewall & Security - lfd…
May 26 15:55:39 **** lfd[18778]: Error Setting IPTABLES is repeated in /etc/csf/csf.conf - you must remove the duplicates and then restart csf and lfd at /usr/local/csf/lib/ConfigServer/URLGet.pm line 26.
May 26 15:55:39 ***** lfd[18778]: Compilation failed in require at /usr/sbin/lfd line 20.
May 26 15:55:39 **** lfd[18778]: BEGIN failed–compilation aborted at /usr/sbin/lfd line 20.
May 26 15:55:39 **** systemd[1]: lfd.service: Control process exited, code=exited, status=255/EXCEPTION
May 26 15:55:39 **** systemd[1]: lfd.service: Failed with result ‘exit-code’.
May 26 15:55:39 **** systemd[1]: Failed to start ConfigServer Firewall & Security - lfd.
@@kooler Fixed my Problem
Thank you so much
