[root@server /]# du -sh cyberpanel.swap
3.7G cyberpanel.swap
Any issue? Can we delete? What is it?
it’s SWAP file just in case server is running on small RAM that result in frequent MariaDB OOM killed.
You can remove it if you wish , but it doesn’t hurt if you leave it
if you want to remove it , delete that file and also edit the file /etc/fstab , remove last line
The Cyberpanel installation in our case is failing because we have a 256GB RAM server and 200GB “/” partition.
The installation is trying to create “/cyberpanel.swap” file with 256GB in size.
The Cyberpanel installation in our case is failing because we have a 256GB RAM server and 200GB "/" partition.The installation is trying to create “/cyberpanel.swap” file with 256GB in size.
I made change to the installer , now no matter what size RAM has , it will create , at maximum 2GB SWAP
