after setting up SSH key-based authentication i used cyperpanel to change de port and disable the root.
everything looks just fine on /etc/ssh/sshd_config but i found “UsePAM yes” and everybody on ubuntu and linux foruns tell me it should be off
- Can we turn UsePam off using cyperpanel?
- Is there a way turn UsePam off with cyberpanel?
- Should cyberpanel as soon it disable the root login, turn UsePam off?
