Cyberpanel PHP path problem
Hi great community.
I’ve searched the threads but haven’t found anything that could help me. I’m not very experienced and I’m trying to learn more about Ubuntu. I installed Cyberpanel and everything works except the PHP changes. If I change the php features in the Cyberpanel panel I don’t see them on the site. I did in info.php which tells me the php is in another path.
Configuration File (php.ini) Path /etc/php/8.0/fpm
Loaded Configuration File /etc/php/8.0/fpm/php.ini
Scan this dir for additional .ini files /etc/php/8.0/fpm/conf.d
It shouldn’t be here:
/usr/local/lsws/lsphpXX/etc/php.ini
or in a similar path?
I can’t solve.
Thanks everyone for the help
Welcome @alebed Happy you are here
Check if you have a different php installed. We recommend you install cyberpanel in a clean installed os (no webservers, no databases, no php, no dns services, no ftp services)
Make sure you are using the correct php on your website manager.
Thanks for Reply… I’ve used a clean installation of Contabo VPS and I’ve installed Cyberpanel at first.
But afterthat the default php path is:
/etc/php/8.0/fpm
If I choose another version of php under site settings nothing change… The strange thnig is that if I change php version under site settings panel, the php changes but the path is always:
/etc/php/XXX/fpm
SOLVED: I’ve change settings under APACHE MANAGER in the website settings.
Thanks foy Help and reply!!!
I’m unable to install WordPress because I encountered an issue when trying to change the default PHP CLI version to 8.1/8.2/8.3.
