CyberPanel on Azure “took too long to respond” even though the IP works fine with terminal and password for the Cyberpanel is issued. Interestingly enough, CyberPanel on AWS can be accessed almost immediately.
Hello @jamesm671
Seems your server is overwhelmed does it meet system requirements ? Also check if resources are depleted maybe running resource intensive websites that need more memory
Thanks for replying. josephgodwinke.
I have not install anything yet. Just launch OLS on Azure (1 core and 1G). Does OLS require more memory?
