@usmannasir Quick question:
Is my understanding correct that CP will pull existing records that were created in CF down to CP as well? Or is my understanding incorrect?
I’ve added a Global Token and get a green success message that "Records successfully fetched for domain domain.com, but don’t see any records reflected in CP.
I’ve disabled locally sync with CF and I only want CF records to be pulled by CP.
Setup:
Ubuntu 22.04, I’ve checked to make sure port 53 is open everywhere. Also tried disabling the whole FW everywhere. Same issue.
Just to add:
Out of curiosity I’ve checked my other installation (not the VPS from above) that’s running 20.04 on Vultr and it works fine on this setup, but not the VPS that’s running 22.04. Both have the most current version of CP
@josephgodwinke You wouldn’t happened to know how to reset or delte the CF/CP connection or sync via terminal command and re-add the connection to see if that fixes the issue?
Cause it does say it successfully fetch the records, but does not display the existing records I can see in CF
There. Read the script to see what it does (you can even reproduce it manually).
Use invoke the script as:
./cloudflare_to_powerdns.sh -k API_KEY -e EMAIL -d “mydomain.com”
It will use your cloudflare email and API key to pull the DNS records for the given mydomain.com and add them to the powerdns database that cyberpanel uses.
Please note that the script uses the default MySQL password generated by cyberpanel, if you have changed it you can either edit the file it read from or hardcode it on the script for the new password:
./cloudflare_to_powerdns.sh: line 15: jq: command not found
Any ideas what that is referring to?
Just to add:
CP does pull from CF on my other setup that is running 20.04. On my 22.04 (where it is not working) is also pulling something but does not display it.
Thanks, didn’t know jq was a package. I tried it, but it didn’t solve the underlying issue. I’m just going to assume it’s a bug. CP tends to have a few bugs here and there.
Yes unfortunately that is just to sync from CF into cyberpanel, needs to be run every time you wish to do it
Not a fix but just a workaround
No problem
