I have pointed my domain to Cloudflare then cyber panel is stopped accessing.
I’m using cloudflare too but make sure that you use that for DNS only and not proxy. In cloudflare, select your domain and go to DNS. Edit those DNS from using proxy (orange cloud) to grey cloud (DNS only). You should have fixed that issue.
@andesjeslis Thanks for your help.
Type your comment> @andesjeslis said:
I’m using cloudflare too but make sure that you use that for DNS only and not proxy. In cloudflare, select your domain and go to DNS. Edit those DNS from using proxy (orange cloud) to grey cloud (DNS only). You should have fixed that issue. mywegmansconnect
Great articles love it good work keep it up
