I have 5 ip addresses in cyberpanel, can I assign these ip addresses to different sites?
@CyberPanel Can you please help me?
1- created an instance on Vultr with an ipv4.
2- installed Cyberpanel on it successfully.
3- also added the second ipv4 on the server.
4- I manually configured additional IPs on my VPS (/etc/sysconfig/network-scripts/ifcfg-eth0, /etc/sysconfig/network-scripts/route-eth0, and, /etc/sysconfig/network-scripts/ifcfg-eth0:1 files)
5- rebooted the network and VPS.
6- Added a new website in the CyberPanel.
7- Changed A record of the new domain to the second IP address.
8- implemented your guide ([Tutorial]How to add 2nd IP for websites — CyberPanel - WebHosting Control Panel for OpenLiteSpeed)
9- Rebooted Litespeed and instance again.
But when I visit the site it doesn’t respond. What is the problem can you please help me?
EDIT: It is fixed, sorry
King regards.
If it’s not too much trouble , please post what did you do to fix it , others may run into same issue and this post might be useful in future
