Cyberpanel installation stuck
i’m trying to install cyberpanel on my server but it getting stuck in the middle of installation.
Vps type: OpenVZ
Os: Almalinux
ERROR:
Checking and installing curl and wget
chmod: cannot access ‘cyberpanel.sh’: No such file or directory
/dev/fd/63: line 49: ./cyberpanel.sh: No such file or directory
[root@vps ~]#
Screenshot: https://i.imgur.com/d2dVnBK.png
Welcome @dadsec Happy you are here
Which Almalinux version are you using ?
sidenote:
This is not a solution but a workaround. OpenVZ although supported is not what I would recommend. Use KVM.
