ashish
November 17, 2022, 5:35pm
1
Hi there, from the last 2 days I tried many times but the cyber panel is not working,
I tried many times but even on a new system after installation it’s just not working I tried on centos 7 & Ubuntu 20.04 after installation when I’m checking running services it’s showing like this as mentioned in below pictures
PowerDNS & pureftpd and openlightspeed are just not working openlightspeed is restarting in a loop after a few seconds and when I checked powerdns it was not even installed on the server
In short cyber panel installation is just not working can you please look into it and please notify me it will be really helpful.
I’m Waiting For Your Reply
Thanks
Please share the output of systemctl status service name.
For litespeed restart issue try commenting
Cronjob line which checking the .htaccess modification.
Powedns: It’s seem you have not selected powerdns during installation or failed to installed due to any reason.
ashish
November 17, 2022, 5:49pm
3
Hi
I just deleted my server, now I’m going to install it again
please check the error log here
opened 01:03AM - 16 Nov 22 UTC
closed 08:04PM - 15 Jan 23 UTC
openlitespeed restarting after every few seconds and crashing again in the loop,… tried this on new installation of centos 7 & ubuntu 20.04.5 both are crashing again and again
error log
2022-11-15 18:59:36.893440 [INFO] [41249] RewriteFile [/home/example.com/public_html/.htaccess] parsed, return 0.
2022-11-15 18:59:36.893634 [INFO] [41249] [PlainConf] [virtualHostTemplate:] start parsing file /usr/local/lsws/conf/templates/ccl.conf
2022-11-15 18:59:36.895073 [INFO] [41249] [PlainConf] [virtualHostTemplate:] Finished parsing file /usr/local/lsws/conf/templates/ccl.conf
2022-11-15 18:59:36.895101 [INFO] [41249] [PlainConf] [context:/] rewrite [] add rules [rewritefile .htaccess]
2022-11-15 18:59:36.895410 [INFO] [41249] [PlainConf] [virtualHostTemplate:] start parsing file /usr/local/lsws/conf/templates/rails.conf
2022-11-15 18:59:36.896651 [INFO] [41249] [PlainConf] [virtualHostTemplate:] Finished parsing file /usr/local/lsws/conf/templates/rails.conf
2022-11-15 18:59:36.896673 [INFO] [41249] [PlainConf] [context:/] rewrite [] add rules [rewritefile .htaccess]
2022-11-15 18:59:36.896891 [NOTICE] [41249] [ZConfManager] No VHosts added, do not send!
2022-11-15 18:59:36.897508 [NOTICE] [41249] Instance is ready for service. m_fdCmd 38, m_fdAdmin 6.
2022-11-15 18:59:36.897950 [NOTICE] [41249] [AutoRestarter] new child process with pid=41252 is forked!
2022-11-15 18:59:36.898248 [NOTICE] [41249] [AutoRestarter] new child process with pid=41253 is forked!
2022-11-15 18:59:36.899269 [INFO] [41253] Close SO_REUSEPORT #1 fd: 24.
2022-11-15 18:59:36.899323 [NOTICE] [41253] [*:80] Worker #2 activates SO_REUSEPORT #2 socket, fd: 25
2022-11-15 18:59:36.899365 [INFO] [41253] Close SO_REUSEPORT #1 fd: 26.
2022-11-15 18:59:36.899376 [NOTICE] [41253] [*:443] Worker #2 activates SO_REUSEPORT #2 socket, fd: 27
2022-11-15 18:59:36.899387 [INFO] [41253] Close SO_REUSEPORT #1 fd: 28.
2022-11-15 18:59:36.899416 [NOTICE] [41253] [UDP *:443] Worker #2 activates SO_REUSEPORT #2 socket, fd: 29
2022-11-15 18:59:36.899473 [INFO] [41253] [UDP:0.0.0.0:443] initPacketsIn: allocated 100 packets
2022-11-15 18:59:36.899493 [INFO] [41253] Close SO_REUSEPORT #1 fd: 30.
2022-11-15 18:59:36.899503 [NOTICE] [41253] [[::]:443] Worker #2 activates SO_REUSEPORT #2 socket, fd: 31
2022-11-15 18:59:36.899523 [NOTICE] [41253] Stop listener *:7080, fd 22.
2022-11-15 18:59:36.899793 [NOTICE] [41253] AIO is not supported on this machine!
2022-11-15 18:59:36.899863 [NOTICE] [41253] Successfully change current user to nobody
2022-11-15 18:59:36.899884 [NOTICE] [41253] Core dump is enabled.
2022-11-15 18:59:36.899920 [NOTICE] [41253] Setup swapping space...
2022-11-15 18:59:36.900000 [NOTICE] [41253] LiteSpeed/1.7.16 Open starts successfully!
2022-11-15 18:59:36.900975 [INFO] [41252] Close SO_REUSEPORT #2 fd: 25.
2022-11-15 18:59:36.901024 [NOTICE] [41252] [*:80] Worker #1 activates SO_REUSEPORT #1 socket, fd: 24
2022-11-15 18:59:36.901061 [INFO] [41252] Close SO_REUSEPORT #2 fd: 27.
2022-11-15 18:59:36.901071 [NOTICE] [41252] [*:443] Worker #1 activates SO_REUSEPORT #1 socket, fd: 26
2022-11-15 18:59:36.901083 [INFO] [41252] Close SO_REUSEPORT #2 fd: 29.
2022-11-15 18:59:36.901093 [NOTICE] [41252] [UDP *:443] Worker #1 activates SO_REUSEPORT #1 socket, fd: 28
2022-11-15 18:59:36.901141 [INFO] [41252] [UDP:0.0.0.0:443] initPacketsIn: allocated 100 packets
2022-11-15 18:59:36.901162 [INFO] [41252] Close SO_REUSEPORT #2 fd: 31.
2022-11-15 18:59:36.901172 [NOTICE] [41252] [[::]:443] Worker #1 activates SO_REUSEPORT #1 socket, fd: 30
2022-11-15 18:59:36.901195 [INFO] [41252] [UDP:0.0.0.0:7080] initPacketsIn: allocated 100 packets
2022-11-15 18:59:36.901453 [NOTICE] [41252] AIO is not supported on this machine!
2022-11-15 18:59:36.901521 [NOTICE] [41252] Successfully change current user to nobody
2022-11-15 18:59:36.901543 [NOTICE] [41252] Core dump is enabled.
2022-11-15 18:59:36.901628 [NOTICE] [41252] Setup swapping space...
2022-11-15 18:59:36.901721 [NOTICE] [41252] LiteSpeed/1.7.16 Open starts successfully!
2022-11-15 18:59:45.484590 [NOTICE] [41249] [AutoRestarter] child process with pid=41253 received signal=4, a core file is created!
2022-11-15 18:59:45.484655 [NOTICE] [41249] [***] will create core file.
2022-11-15 18:59:46.081251 [NOTICE] [41252] Start shutting down gracefully ...
2022-11-15 18:59:46.081278 [NOTICE] [41252] New litespeed process is ready, stop listeners
2022-11-15 18:59:46.081289 [NOTICE] [41252] Stop listener *:80, fd 24.
2022-11-15 18:59:46.081364 [NOTICE] [41252] Stop listener *:443, fd 26.
2022-11-15 18:59:46.081384 [NOTICE] [41252] Stop listener [::]:443, fd 30.
2022-11-15 18:59:46.081405 [NOTICE] [41252] Stop listener *:7080, fd 22.
2022-11-15 18:59:46.081470 [NOTICE] [41252] Event-loop lingering start.
