Starting installation…,1
Initialization completed…,2
Setting up repositories…,1
Installing necessary components…,3
Installing required virtual environment,3
Installing requirments…,3
Getting CyberPanel code…,4
Necessary components installed…,5
Setting up system tweak…,20
Starting main installation…,30
[09.19.2021_00-30-39] Starting CyberPanel installation…,10
[09.19.2021_00-31-03] Running: dd if=/dev/zero of=/usr/.tempdisk bs=100M count=15,10
[09.19.2021_00-31-22] Successfully ran: dd if=/dev/zero of=/usr/.tempdisk bs=100M count=15.,10
[09.19.2021_00-31-35] Running: mkfs.ext4 -F /usr/.tempdisk,10
[09.19.2021_00-31-49] Successfully ran: mkfs.ext4 -F /usr/.tempdisk.,10
[09.19.2021_00-32-03] Running: mkdir -p /usr/.tmpbak/,10
[09.19.2021_00-32-17] Successfully ran: mkdir -p /usr/.tmpbak/.,10
[09.19.2021_00-32-18] Running: mount -o loop-rw-nodev-nosuid-noexec-nofail /usr/.tempdisk /tmp,10
[09.19.2021_00-32-19] Successfully ran: mount -o loop-rw-nodev-nosuid-noexec-nofail /usr/.tempdisk /tmp.,10
[09.19.2021_00-32-26] Running: chmod 1777 /tmp,10
[09.19.2021_00-32-39] Successfully ran: chmod 1777 /tmp.,10
[09.19.2021_00-32-40] Running: rm -rf /usr/.tmpbak,10
[09.19.2021_00-32-54] Successfully ran: rm -rf /usr/.tmpbak.,10
[09.19.2021_00-32-55] Running: mount --bind /tmp /var/tmp,10
[09.19.2021_00-32-56] Successfully ran: mount --bind /tmp /var/tmp.,10
[09.19.2021_00-32-58] Running: yum install sudo -y,10
[09.19.2021_00-33-02] Successfully ran: yum install sudo -y.,10
[09.19.2021_00-33-14] Running: useradd -s /bin/false cyberpanel,10
[09.19.2021_00-33-25] Successfully ran: useradd -s /bin/false cyberpanel.,10
[09.19.2021_00-33-26] Running: adduser docker,10
[09.19.2021_00-33-27] Successfully ran: adduser docker.,10
[09.19.2021_00-33-37] Running: groupadd docker,10
[09.19.2021_00-33-38] [ERROR] We are not able to run groupadd docker return code: 9.,10
[09.19.2021_00-33-39] Running: usermod -aG docker docker,10
[09.19.2021_00-33-39] Successfully ran: usermod -aG docker docker.,10
[09.19.2021_00-33-40] Running: usermod -aG docker cyberpanel,10
[09.19.2021_00-33-41] Successfully ran: usermod -aG docker cyberpanel.,10
[09.19.2021_00-33-51] Running: mkdir -p /etc/letsencrypt/live/,10
[09.19.2021_00-33-52] Successfully ran: mkdir -p /etc/letsencrypt/live/.,10
[09.19.2021_00-34-10] Running: rpm -ivh http://rpms.litespeedtech.com/centos/litespeed-repo-1.2-1.el7.noarch.rpm,10
[09.19.2021_00-34-25] Successfully ran: rpm -ivh http://rpms.litespeedtech.com/centos/litespeed-repo-1.2-1.el7.noarch.rpm.,10
[09.19.2021_00-34-35] Running: ,10
[09.19.2021_00-34-50] Successfully ran: .,10
[09.19.2021_00-34-51] Running: ,10
[09.19.2021_00-34-53] Successfully ran: .,10
[09.19.2021_00-34-54] Installing LiteSpeed Web server,40
[09.19.2021_00-35-13] Running: yum install -y openlitespeed,40
[09.19.2021_00-35-54] Successfully ran: yum install -y openlitespeed.,40
[09.19.2021_00-35-56] Changing default port to 80…,40
[09.19.2021_00-36-09] Default port is now 80 for OpenLiteSpeed!,40
[09.19.2021_00-36-10] Running: /usr/local/lsws/bin/lswsctrl restart,40
[09.19.2021_00-36-27] Successfully ran: /usr/local/lsws/bin/lswsctrl restart.,40
[09.19.2021_00-36-37] Installing Optimized PHPs…,50
[09.19.2021_00-36-37] Running: yum -y groupinstall lsphp-all,50
[09.19.2021_00-37-35] Successfully ran: yum -y groupinstall lsphp-all.,50
[09.19.2021_00-37-37] LiteSpeed PHPs successfully installed!,50
[09.19.2021_00-37-38] Running: yum install lsphp71 lsphp71-json lsphp71-xmlrpc lsphp71-xml lsphp71-soap lsphp71-snmp lsphp71-recode lsphp71-pspell lsphp71-process lsphp71-pgsql lsphp71-pear lsphp71-pdo lsphp71-opcache lsphp71-odbc lsphp71-mysqlnd lsphp71-mcrypt lsphp71-mbstring lsphp71-ldap lsphp71-intl lsphp71-imap lsphp71-gmp lsphp71-gd lsphp71-enchant lsphp71-dba lsphp71-common lsphp71-bcmath -y,50
[09.19.2021_00-38-03] Successfully ran: yum install lsphp71 lsphp71-json lsphp71-xmlrpc lsphp71-xml lsphp71-soap lsphp71-snmp lsphp71-recode lsphp71-pspell lsphp71-process lsphp71-pgsql lsphp71-pear lsphp71-pdo lsphp71-opcache lsphp71-odbc lsphp71-mysqlnd lsphp71-mcrypt lsphp71-mbstring lsphp71-ldap lsphp71-intl lsphp71-imap lsphp71-gmp lsphp71-gd lsphp71-enchant lsphp71-dba lsphp71-common lsphp71-bcmath -y.,50
[09.19.2021_00-38-04] Running: yum install -y lsphp72 lsphp72-json lsphp72-xmlrpc lsphp72-xml lsphp72-soap lsphp72-snmp lsphp72-recode lsphp72-pspell lsphp72-process lsphp72-pgsql lsphp72-pear lsphp72-pdo lsphp72-opcache lsphp72-odbc lsphp72-mysqlnd lsphp72-mcrypt lsphp72-mbstring lsphp72-ldap lsphp72-intl lsphp72-imap lsphp72-gmp lsphp72-gd lsphp72-enchant lsphp72-dba lsphp72-common lsphp72-bcmath,50
[09.19.2021_00-38-24] Successfully ran: yum install -y lsphp72 lsphp72-json lsphp72-xmlrpc lsphp72-xml lsphp72-soap lsphp72-snmp lsphp72-recode lsphp72-pspell lsphp72-process lsphp72-pgsql lsphp72-pear lsphp72-pdo lsphp72-opcache lsphp72-odbc lsphp72-mysqlnd lsphp72-mcrypt lsphp72-mbstring lsphp72-ldap lsphp72-intl lsphp72-imap lsphp72-gmp lsphp72-gd lsphp72-enchant lsphp72-dba lsphp72-common lsphp72-bcmath.,50
[09.19.2021_00-38-25] Running: yum install -y lsphp73 lsphp73-json lsphp73-xmlrpc lsphp73-xml lsphp73-tidy lsphp73-soap lsphp73-snmp lsphp73-recode lsphp73-pspell lsphp73-process lsphp73-pgsql lsphp73-pear lsphp73-pdo lsphp73-opcache lsphp73-odbc lsphp73-mysqlnd lsphp73-mcrypt lsphp73-mbstring lsphp73-ldap lsphp73-intl lsphp73-imap lsphp73-gmp lsphp73-gd lsphp73-enchant lsphp73-dba lsphp73-common lsphp73-bcmath,50
[09.19.2021_00-38-47] Successfully ran: yum install -y lsphp73 lsphp73-json lsphp73-xmlrpc lsphp73-xml lsphp73-tidy lsphp73-soap lsphp73-snmp lsphp73-recode lsphp73-pspell lsphp73-process lsphp73-pgsql lsphp73-pear lsphp73-pdo lsphp73-opcache lsphp73-odbc lsphp73-mysqlnd lsphp73-mcrypt lsphp73-mbstring lsphp73-ldap lsphp73-intl lsphp73-imap lsphp73-gmp lsphp73-gd lsphp73-enchant lsphp73-dba lsphp73-common lsphp73-bcmath.,50
[09.19.2021_00-38-55] Running: yum install -y lsphp74 lsphp74-json lsphp74-xmlrpc lsphp74-xml lsphp74-tidy lsphp74-soap lsphp74-snmp lsphp74-recode lsphp74-pspell lsphp74-process lsphp74-pgsql lsphp74-pear lsphp74-pdo lsphp74-opcache lsphp74-odbc lsphp74-mysqlnd lsphp74-mcrypt lsphp74-mbstring lsphp74-ldap lsphp74-intl lsphp74-imap lsphp74-gmp lsphp74-gd lsphp74-enchant lsphp74-dba lsphp74-common lsphp74-bcmath,50
[09.19.2021_00-39-16] Successfully ran: yum install -y lsphp74 lsphp74-json lsphp74-xmlrpc lsphp74-xml lsphp74-tidy lsphp74-soap lsphp74-snmp lsphp74-recode lsphp74-pspell lsphp74-process lsphp74-pgsql lsphp74-pear lsphp74-pdo lsphp74-opcache lsphp74-odbc lsphp74-mysqlnd lsphp74-mcrypt lsphp74-mbstring lsphp74-ldap lsphp74-intl lsphp74-imap lsphp74-gmp lsphp74-gd lsphp74-enchant lsphp74-dba lsphp74-common lsphp74-bcmath.,50
[09.19.2021_00-39-45] Fixing OpenLiteSpeed configurations!,50
[09.19.2021_00-39-45] OpenLiteSpeed Configurations fixed!,50
[09.19.2021_00-39-46] Running: /usr/local/lsws/bin/lswsctrl restart,50
[09.19.2021_00-39-54] Successfully ran: /usr/local/lsws/bin/lswsctrl restart.,50
[09.19.2021_00-39-58] Installing MySQL,60
[09.19.2021_00-39-59] Running: yum --enablerepo=mariadb -y install MariaDB-server MariaDB-client,60
[09.19.2021_00-41-00] Successfully ran: yum --enablerepo=mariadb -y install MariaDB-server MariaDB-client.,60
[09.19.2021_00-41-15] Running: yum install -y pure-ftpd,60
[09.19.2021_00-41-22] Successfully ran: yum install -y pure-ftpd.,60
[09.19.2021_00-41-27] Running: systemctl enable pure-ftpd,60
[09.19.2021_00-41-28] Successfully ran: systemctl enable pure-ftpd.,60
[09.19.2021_00-41-30] Running: groupadd -g 2001 ftpgroup,60
[09.19.2021_00-41-31] Successfully ran: groupadd -g 2001 ftpgroup.,60
[09.19.2021_00-41-34] Running: useradd -u 2001 -s /bin/false -d /bin/null -c “pureftpd user” -g ftpgroup ftpuser,60
[09.19.2021_00-41-35] Successfully ran: useradd -u 2001 -s /bin/false -d /bin/null -c “pureftpd user” -g ftpgroup ftpuser.,60
[09.19.2021_00-41-40] Configuring PureFTPD…,60
[09.19.2021_00-41-43] Running: openssl req -newkey rsa:1024 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/ssl/private/pure-ftpd.pem -out /etc/ssl/private/pure-ftpd.pem,60
[09.19.2021_00-41-46] Successfully ran: openssl req -newkey rsa:1024 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/ssl/private/pure-ftpd.pem -out /etc/ssl/private/pure-ftpd.pem.,60
[09.19.2021_00-41-49] Running: sed -i ‘s|localhost|192.168.5.45|g’ /etc/pure-ftpd/pureftpd-mysql.conf,60
[09.19.2021_00-41-50] Successfully ran: sed -i ‘s|localhost|192.168.5.45|g’ /etc/pure-ftpd/pureftpd-mysql.conf.,60
[09.19.2021_00-41-51] Running: sed -i ‘s|3306|3306|g’ /etc/pure-ftpd/pureftpd-mysql.conf,60
[09.19.2021_00-41-51] Successfully ran: sed -i ‘s|3306|3306|g’ /etc/pure-ftpd/pureftpd-mysql.conf.,60
[09.19.2021_00-41-53] Running: sed -i ‘s|MYSQLSocket /var/lib/mysql/mysql.sock||g’ /etc/pure-ftpd/pureftpd-mysql.conf,60
[09.19.2021_00-41-53] Successfully ran: sed -i ‘s|MYSQLSocket /var/lib/mysql/mysql.sock||g’ /etc/pure-ftpd/pureftpd-mysql.conf.,60
[09.19.2021_00-41-54] PureFTPD configured!,60
[09.19.2021_00-41-55] Running: systemctl start pure-ftpd,60
[09.19.2021_00-41-57] Successfully ran: systemctl start pure-ftpd.,60
[09.19.2021_00-41-59] Running: yum -y install pdns pdns-backend-mysql,60
[09.19.2021_00-42-10] Successfully ran: yum -y install pdns pdns-backend-mysql.,60
[09.19.2021_00-42-11] Configuring PowerDNS…,60
[09.19.2021_00-42-11] Running: sed -i ‘s|gmysql-host=localhost|gmysql-host=192.168.5.45|g’ /etc/pdns/pdns.conf,60
[09.19.2021_00-42-12] Successfully ran: sed -i ‘s|gmysql-host=localhost|gmysql-host=192.168.5.45|g’ /etc/pdns/pdns.conf.,60
[09.19.2021_00-42-13] Running: sed -i ‘s|gmysql-port=3306|gmysql-port=3306|g’ /etc/pdns/pdns.conf,60
[09.19.2021_00-42-16] Successfully ran: sed -i ‘s|gmysql-port=3306|gmysql-port=3306|g’ /etc/pdns/pdns.conf.,60
[09.19.2021_00-42-17] PowerDNS configured!,60
[09.19.2021_00-42-18] Running: systemctl enable pdns,60
[09.19.2021_00-42-18] Successfully ran: systemctl enable pdns.,60
[09.19.2021_00-42-19] Running: systemctl start pdns,60
[09.19.2021_00-42-24] Successfully ran: systemctl start pdns.,60
[09.19.2021_00-42-26] Running: cp /usr/local/lsws/lsphp71/bin/php /usr/bin/,60
[09.19.2021_00-42-28] Successfully ran: cp /usr/local/lsws/lsphp71/bin/php /usr/bin/.,60
[09.19.2021_00-42-28] Running: chmod +x composer.sh,60
[09.19.2021_00-42-32] Successfully ran: chmod +x composer.sh.,60
[09.19.2021_00-42-33] Running: ./composer.sh,60
[09.19.2021_00-42-41] Successfully ran: ./composer.sh.,60
[09.19.2021_00-42-45] fix_selinux_issue problem,60
[09.19.2021_00-42-45] Running: yum -y install psmisc,60
[09.19.2021_00-42-52] Successfully ran: yum -y install psmisc.,60
[09.19.2021_00-42-53] Running: yum remove postfix -y,60
[09.19.2021_00-42-59] Successfully ran: yum remove postfix -y.,60
[09.19.2021_00-43-00] Running: yum install --enablerepo=gf-plus -y postfix3 postfix3-ldap postfix3-mysql postfix3-pcre,60
[09.19.2021_00-43-30] Successfully ran: yum install --enablerepo=gf-plus -y postfix3 postfix3-ldap postfix3-mysql postfix3-pcre.,60
[09.19.2021_00-43-31] Running: yum install --enablerepo=gf-plus -y postfix3 postfix3-ldap postfix3-mysql postfix3-pcre,60
[09.19.2021_00-43-35] Successfully ran: yum install --enablerepo=gf-plus -y postfix3 postfix3-ldap postfix3-mysql postfix3-pcre.,60
[09.19.2021_00-43-36] Running: yum --enablerepo=gf-plus -y install dovecot23 dovecot23-mysql,60
[09.19.2021_01-15-00] Successfully ran: yum --enablerepo=gf-plus -y install dovecot23 dovecot23-mysql.,60
[09.19.2021_01-15-00] Setting up authentication for Postfix and Dovecot…,60
[09.19.2021_01-15-02] Running: sed -i ‘s|host=localhost|host=192.168.5.45|g’ email-configs-one/dovecot-sql.conf.ext,60
[09.19.2021_01-15-03] Successfully ran: sed -i ‘s|host=localhost|host=192.168.5.45|g’ email-configs-one/dovecot-sql.conf.ext.,60
[09.19.2021_01-15-03] Running: sed -i ‘s|port=3306|port=3306|g’ email-configs-one/dovecot-sql.conf.ext,60
[09.19.2021_01-15-04] Successfully ran: sed -i ‘s|port=3306|port=3306|g’ email-configs-one/dovecot-sql.conf.ext.,60
[09.19.2021_01-15-05] Running: sed -i ‘s|localhost|192.168.5.45:3306|g’ email-configs-one/mysql-virtual_domains.cf,60
[09.19.2021_01-15-07] Successfully ran: sed -i ‘s|localhost|192.168.5.45:3306|g’ email-configs-one/mysql-virtual_domains.cf.,60
[09.19.2021_01-15-07] Running: sed -i ‘s|localhost|192.168.5.45:3306|g’ email-configs-one/mysql-virtual_forwardings.cf,60
[09.19.2021_01-15-09] Successfully ran: sed -i ‘s|localhost|192.168.5.45:3306|g’ email-configs-one/mysql-virtual_forwardings.cf.,60
[09.19.2021_01-15-09] Running: sed -i ‘s|localhost|192.168.5.45:3306|g’ email-configs-one/mysql-virtual_mailboxes.cf,60
[09.19.2021_01-15-10] Successfully ran: sed -i ‘s|localhost|192.168.5.45:3306|g’ email-configs-one/mysql-virtual_mailboxes.cf.,60
[09.19.2021_01-15-10] Running: sed -i ‘s|localhost|192.168.5.45:3306|g’ email-configs-one/mysql-virtual_email2email.cf,60
[09.19.2021_01-15-11] Successfully ran: sed -i ‘s|localhost|192.168.5.45:3306|g’ email-configs-one/mysql-virtual_email2email.cf.,60
[09.19.2021_01-15-11] Authentication for Postfix and Dovecot set.,60
[09.19.2021_01-15-12] Configuring postfix and dovecot…,60
[09.19.2021_01-15-13] Running: openssl req -newkey rsa:2048 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/postfix/key.pem -out /etc/postfix/cert.pem,60
[09.19.2021_01-15-14] Successfully ran: openssl req -newkey rsa:2048 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/postfix/key.pem -out /etc/postfix/cert.pem.,60
[09.19.2021_01-15-15] Running: openssl req -newkey rsa:2048 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/dovecot/key.pem -out /etc/dovecot/cert.pem,60
[09.19.2021_01-15-16] Successfully ran: openssl req -newkey rsa:2048 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/dovecot/key.pem -out /etc/dovecot/cert.pem.,60
[09.19.2021_01-15-17] Running: postconf -e ‘myhostname = localhost.localdomain’,60
[09.19.2021_01-15-17] Successfully ran: postconf -e ‘myhostname = localhost.localdomain’.,60
[09.19.2021_01-15-18] Running: sed -i ‘s|server.example.com|localhost.localdomain|g’ /etc/postfix/main.cf,60
[09.19.2021_01-15-19] Successfully ran: sed -i ‘s|server.example.com|localhost.localdomain|g’ /etc/postfix/main.cf.,60
[09.19.2021_01-15-19] Running: chmod o= /etc/postfix/mysql-virtual_domains.cf,60
[09.19.2021_01-15-20] Successfully ran: chmod o= /etc/postfix/mysql-virtual_domains.cf.,60
[09.19.2021_01-15-20] Running: chmod o= /etc/postfix/mysql-virtual_forwardings.cf,60
[09.19.2021_01-15-21] Successfully ran: chmod o= /etc/postfix/mysql-virtual_forwardings.cf.,60
[09.19.2021_01-15-22] Running: chmod o= /etc/postfix/mysql-virtual_mailboxes.cf,60
[09.19.2021_01-15-22] Successfully ran: chmod o= /etc/postfix/mysql-virtual_mailboxes.cf.,60
[09.19.2021_01-15-23] Running: chmod o= /etc/postfix/mysql-virtual_email2email.cf,60
[09.19.2021_01-15-23] Successfully ran: chmod o= /etc/postfix/mysql-virtual_email2email.cf.,60
[09.19.2021_01-15-24] Running: chmod o= /etc/postfix/main.cf,60
[09.19.2021_01-15-25] Successfully ran: chmod o= /etc/postfix/main.cf.,60
[09.19.2021_01-15-26] Running: chmod o= /etc/postfix/master.cf,60
[09.19.2021_01-15-26] Successfully ran: chmod o= /etc/postfix/master.cf.,60
[09.19.2021_01-15-27] Running: chgrp postfix /etc/postfix/mysql-virtual_domains.cf,60
[09.19.2021_01-15-28] Successfully ran: chgrp postfix /etc/postfix/mysql-virtual_domains.cf.,60
[09.19.2021_01-15-28] Running: chgrp postfix /etc/postfix/mysql-virtual_forwardings.cf,60
[09.19.2021_01-15-30] Successfully ran: chgrp postfix /etc/postfix/mysql-virtual_forwardings.cf.,60
[09.19.2021_01-15-30] Running: chgrp postfix /etc/postfix/mysql-virtual_mailboxes.cf,60
[09.19.2021_01-15-31] Successfully ran: chgrp postfix /etc/postfix/mysql-virtual_mailboxes.cf.,60
[09.19.2021_01-15-31] Running: chgrp postfix /etc/postfix/mysql-virtual_email2email.cf,60
[09.19.2021_01-15-32] Successfully ran: chgrp postfix /etc/postfix/mysql-virtual_email2email.cf.,60
[09.19.2021_01-15-33] Running: chgrp postfix /etc/postfix/main.cf,60
[09.19.2021_01-15-33] Successfully ran: chgrp postfix /etc/postfix/main.cf.,60
[09.19.2021_01-15-34] Running: chgrp postfix /etc/postfix/master.cf,60
[09.19.2021_01-15-34] Successfully ran: chgrp postfix /etc/postfix/master.cf.,60
[09.19.2021_01-15-35] Running: groupadd -g 5000 vmail,60
[09.19.2021_01-15-35] Successfully ran: groupadd -g 5000 vmail.,60
[09.19.2021_01-15-36] Running: useradd -g vmail -u 5000 vmail -d /home/vmail -m,60
[09.19.2021_01-15-36] Successfully ran: useradd -g vmail -u 5000 vmail -d /home/vmail -m.,60
[09.19.2021_01-15-37] Running: systemctl enable postfix.service,60
[09.19.2021_01-15-37] Successfully ran: systemctl enable postfix.service.,60
[09.19.2021_01-15-38] Running: systemctl start postfix.service,60
[09.19.2021_01-15-39] Successfully ran: systemctl start postfix.service.,60
[09.19.2021_01-15-40] Running: chgrp dovecot /etc/dovecot/dovecot-sql.conf.ext,60
[09.19.2021_01-15-40] Successfully ran: chgrp dovecot /etc/dovecot/dovecot-sql.conf.ext.,60
[09.19.2021_01-15-41] Running: chmod o= /etc/dovecot/dovecot-sql.conf.ext,60
[09.19.2021_01-15-41] Successfully ran: chmod o= /etc/dovecot/dovecot-sql.conf.ext.,60
[09.19.2021_01-15-42] Running: systemctl enable dovecot.service,60
[09.19.2021_01-15-43] Successfully ran: systemctl enable dovecot.service.,60
[09.19.2021_01-15-44] Running: systemctl start dovecot.service,60
[09.19.2021_01-15-45] Successfully ran: systemctl start dovecot.service.,60
[09.19.2021_01-15-45] Running: systemctl restart postfix.service,60
[09.19.2021_01-15-46] Successfully ran: systemctl restart postfix.service.,60
[09.19.2021_01-15-47] Running: chmod 755 /etc/postfix/main.cf,60
[09.19.2021_01-15-47] Successfully ran: chmod 755 /etc/postfix/main.cf.,60
[09.19.2021_01-15-48] Postfix and Dovecot configured,60
[09.19.2021_01-15-48] Running: yum -y install unzip,60
[09.19.2021_01-15-52] Successfully ran: yum -y install unzip.,60
[09.19.2021_01-15-53] Running: yum -y install zip,60
[09.19.2021_01-15-57] Successfully ran: yum -y install zip.,60
[09.19.2021_01-15-57] Running: yum -y install rsync,60
[09.19.2021_01-16-00] Successfully ran: yum -y install rsync.,60
[09.19.2021_01-16-01] Running: yum -y install firewalld,60
[09.19.2021_01-16-04] Successfully ran: yum -y install firewalld.,60
[09.19.2021_01-16-05] Running: systemctl restart dbus,60
[09.19.2021_01-16-06] Successfully ran: systemctl restart dbus.,60
[09.19.2021_01-16-07] Running: systemctl restart systemd-logind,60
[09.19.2021_01-16-08] Successfully ran: systemctl restart systemd-logind.,60
[09.19.2021_01-16-08] Running: systemctl start firewalld,60
[09.19.2021_01-16-09] Successfully ran: systemctl start firewalld.,60
[09.19.2021_01-16-09] Running: systemctl enable firewalld,60
[09.19.2021_01-16-10] Successfully ran: systemctl enable firewalld.,60
[09.19.2021_01-16-28] FirewallD installed and configured!,60
[09.19.2021_01-16-29] Running: ssh-keygen -f /root/.ssh/cyberpanel -t rsa -N ‘’,60
[09.19.2021_01-16-30] Successfully ran: ssh-keygen -f /root/.ssh/cyberpanel -t rsa -N ‘’.,60
[09.19.2021_01-16-30] Running: echo downloaded,60
[09.19.2021_01-16-31] Successfully ran: echo downloaded.,60
[09.19.2021_01-16-32] Updating /root/.my.cnf!,60
[09.19.2021_01-16-33] Updating settings.py!,60
[09.19.2021_01-16-34] Running: sed -i ‘s|localhost|192.168.5.45|g’ /usr/local/CyberCP/CyberCP/settings.py,60
[09.19.2021_01-16-35] Successfully ran: sed -i ‘s|localhost|192.168.5.45|g’ /usr/local/CyberCP/CyberCP/settings.py.,60
[09.19.2021_01-16-35] Running: sed -i ‘s|root|root|g’ /usr/local/CyberCP/CyberCP/settings.py,60
[09.19.2021_01-16-36] Successfully ran: sed -i ‘s|root|root|g’ /usr/local/CyberCP/CyberCP/settings.py.,60
[09.19.2021_01-16-37] Running: sed -i “s|‘PORT’: ‘’|‘PORT’:‘3306’|g” /usr/local/CyberCP/CyberCP/settings.py,60
[09.19.2021_01-16-37] Successfully ran: sed -i “s|‘PORT’: ‘’|‘PORT’:‘3306’|g” /usr/local/CyberCP/CyberCP/settings.py.,60
[09.19.2021_01-16-38] settings.py updated!,60
[09.19.2021_01-16-39] Running: /usr/local/CyberPanel/bin/python manage.py makemigrations,60
[09.19.2021_01-16-43] [ERROR] We are not able to run /usr/local/CyberPanel/bin/python manage.py makemigrations return code: 1. Fatal error, see /var/log/installLogs.txt for full details.
[09.19.2021_01-16-45] [ERROR] We are not able to run /usr/local/CyberPanel/bin/python manage.py makemigrations return code: 1. Fatal error, see /var/log/installLogs.txt for full details.
Oops, something went wrong… [404]
