New installation of OS & CyberPanel - latest version.
Has anyone installed CyberPanel on AlmaLinux 8.5 or Ubuntu Server 20.04.3 LTS and the commands work for them?
Please try to reinstall Almalinux 8.5 fresh and then install cyberpanel 2.1.2
There maybe something wrong. Which hosting provider you are using?
Mine is working very fine. Also, I am unable to understand where exactly are those options which you stated, cyberpanel help, upgrade and utility? Please explain in detail.
The commands are displayed with the CyberPanel installation confirmation. It’s the same confirmation that has info on accessing CyberPanel / OLS Webadmin, links for CyberPanel Forum / website etc and passwords etc.
Any screenshot of those functions you mentioned? I haven’t came across any such option while installing or I may have missed something?
It happens every time I install CyberPanel using the install script. Once the script runs it give you passwords for CyberPanel, OLS webadmin and Rainloop. It is there I can see the command options and links to the forum etc. Next time I install I will send you a screenshot.
Now I got it. You mean to say is the last success message you get after cyberpanel installion on the SSH display as below:
Run cyberpanel help to get FAQ info
Run cyberpanel upgrade to upgrade it to latest version.
Run cyberpanel utility to access some handy tools.
Website : https://www.cyberpanel.net
Forums : https://forums.cyberpanel.net
Wikipage: https://docs.cyberpanel.net
Docs : https://cyberpanel.net/docs/
Enjoy your accelerated Internet by
CyberPanel & OpenLiteSpeed
This is just a welcome message made long time back and may not have updated and it has nothing to do with the cyberpanel functioning. Its just a premade text to welcome the user with all the details displayed after installation. You can ignore it.
The cyberpanel upgrade commands does the upgrade but it wont diplay anything on screen. If you want to see all the details live while upgrading, use the upgrade script mentioned in documentation.
