Originally I used Intel Chips on Hosts, for the last 3 years I use AMD Chips first installing Ubuntu Server then Installing CyberPanel
I see there are different packages installed per CPU type.
Does CyberPanel behave differently depending on what CPU type is used?
is there a side by side comparison?
note: I tried installed on an ARM CPU and got plenty of errors port install. So there is certainly a difference there.
I think the userbase would be interested to know the answer to this question if there has been testing.
