CyberPanel CSF Firewall Configuration Issues - Need Help
Hello CyberPanel Community!
I’m facing several serious issues while configuring CSF (ConfigServer Security & Firewall) in my CyberPanel environment and would appreciate your assistance.
Problem 1: CSF Web Interface Configuration Save Error
Every time I try to change and save settings through the CSF web interface, I encounter the following error:
json
  "error_message": "Data supplied is not accepted, following characters are not allowed in the input ` $ & ( ) [ ] { } ; : \u2018 < >.",
  "errorMessage": "Data supplied is not accepted, following characters are not allowed in the input ` $ & ( ) [ ] { } ; : \u2018 < >."
Question: What causes this error? Is there a way to make CSF configuration changes through the web interface?
Currently, I can only make configuration changes through the terminal.
Problem 2: HTACCESS_LOG Configuration Change Rationale
Initially, the CSF configuration had HTACCESS_LOG set as follows:
bash
HTACCESS_LOG = "/usr/local/lsws/logs/error.log"
However, since the 404 error-based automatic blocking feature (LF_APACHE_404) wasn’t working, I changed it to:
bash
HTACCESS_LOG = "/usr/local/lsws/logs/access.log"
Change Rationale:
  • error.log is a web server error log that records server internal processing errors and configuration issues
  • access.log is an HTTP request log that includes IP addresses, status codes (including 404), request URLs, etc.
  • The LF_APACHE_404 feature needs to detect 404 status codes, so HTTP request records are necessary
  • Therefore, access.log is the correct choice
Question: Is this change in the right direction? What is the correct log file path for the LF_APACHE_404 feature in CyberPanel + OpenLiteSpeed environment?
Problem 3: LF_APACHE_404 Feature Completely Non-functional
Despite configuring as follows, the 404 error-based automatic blocking is not working at all:
bash
LF_APACHE_404 = "60"
LF_INTERVAL = "3600"
TESTING = "0"
Confirmed Normal Status:
  • LFD service running normally (systemctl status lfd)
  • Log file being monitored normally (lsof -p $(pgrep lfd) | grep access.log)
  • OpenLiteSpeed log files added to csf.logfiles
  • Log format fully compatible with Apache standard
Test Results:
  • Intentionally generated 60+ 404 errors → No response
  • grep "lfd:" /etc/csf/csf.deny → No results
  • grep "PERMBLOCK" /var/log/lfd.log → No results
Questions:
  1. Are there any cases where the LF_APACHE_404 feature works normally in CyberPanel + OpenLiteSpeed environment?
  2. Could there be additional configuration or permission issues?
  3. Are other CyberPanel users experiencing the same problem?
Environment Information
  • CyberPanel Version: 2.4 (Build 2)
  • Current Commit: f745bb558db518123f0d37831ba0b58eb5bb0390
  • CSF Version: v14.24 (CyberPanel)
  • Web Server: OpenLiteSpeed
  • OS: Ubuntu/CentOS [version]
  • Timezone: Asia/Seoul (KST, +0900)
Requests
  1. CSF web interface error resolution method
  2. LF_APACHE_404 feature activation method
  3. Proper CSF configuration guide for CyberPanel environment
  4. Sharing similar experiences from other users
I would appreciate help from those who have experienced similar issues or know how to resolve them.
Thank you!
