For the past 2 days, around ~14:00, the CPU usage starts to spike almost to 100%, making it nearly impossible for ALL my websites to function properly. I have the latest version of CyberPanel, a Lightspeed server on Contabo with around 10 WordPress websites. The server specifications are adequate: VPS XL NVMe with 10 CPU cores and 60 GB RAM.
I discovered that the issue is limited to a specific WordPress WooCommerce site, likely due to an incompatibility between the latest WooCommerce version and a plugin. My problem and question are: how can I immediately identify the exact cause of this CPU problem? Specifically, it’s clear that it comes from the website, but what exactly is causing it? And most importantly, I find it a major issue that one website can consume all the CPU resources, causing the others to slow down! Is it possible to set a CPU usage limit per page, like we do with memory within WordPress? I feel like I don’t have control over my clients if I don’t know what is consuming memory or CPU. The only command I can use to see some things from the command prompt is htop.
