Faced some issue with Cyberpanel admin login. Seems missing stylesheet and js, or probably Permissions problem and Cyberpanel cannot access css and js to load. Any ideas how to fix this, where to look for permissions to change?
Clear your cache and if use ad blocker disable it.
Still the same issue, adblocker disabled and cachne cleared. Is it displays same for you on a link https://45.93.136.236:8090/ ?
Does not look right… Try run update and see if that helps.
I cannot even login to admin panel, how can I run update through SSH then?
Yes SSH check cyberpanel documents section you find command to run update.
Thank you, that helped!
