Hi all,
Does anyone know how to add a custom menu link into the panel or if possible?
For example if I want to add a link to https://hostname/app/
Even if on existing link like plugins is OK just need to know the file location.
Thanks
Hi all,
Thanks
I have actually just found it by downloading cp from github and searching for the connect link should have done in the first place.
