CSF not blocking
I tried installing and uninstalling. turning the firewald on and off and disabled it and still nothing.
CSF is working and running but it is not blocking. I want to block all IP which is 0.0.0.0/0 and only allow IP that I specify but it is still allowing IP that is not in the allowed and ignored list. What should I do with this?
I followed this CSF anf Firewall Conflict
I installed it manually but the $ tar -xvfz csf.tgz command is not working.
0.0.0.0/0 is not for all add ALL to block all IP and allow the IP in allow list
I removed the 0.0.0.0/0 and changed it to ALL but it is still not blocking access from other IPs
this is the error
“IPSET: [ipset v7.5: The value of the CIDR parameter of the IP address is invalid]”
