Hello guys, i’ve installed Mautic, downloading the zip file, extract and install it. Everything is working fine but cronjob not running.
The mautic is running under subdomain, like marketing.domain.com.br
I did the cronjob setup from cyberpanel CRON MANAGEMENT with user account ( not admin).
To try to figured out, I did run the command from SSH, with root user and website user.
I’m using PHP 7.4 on Mautic and on default PHP version
When I run the command with the website user,
wwwli8536@vps10: php /home/domain.com.br/marketing/login/bin/console mautic:segments:update
PHP Warning: fopen(/home/domain.com.br/marketing/login/var/cache/prod/…/run/sf.mautic-segments-update.5415eaf7823c0a036b252ba8a9f1f4065263e1c60a23cacf6b5851144245b8c9.lock): failed to open stream: Permission denied in /home/domain.com.br/marketing/login/app/bundles/CoreBundle/Command/ModeratedCommand.php on line 154
PHP Warning: flock() expects parameter 1 to be resource, bool given in /home/domain.com.br/marketing/login/app/bundles/CoreBundle/Command/ModeratedCommand.php on line 155
Failed to lock /home/domain.com.br/marketing/login/var/cache/prod/…/run/sf.mautic-segments-update.5415eaf7823c0a036b252ba8a9f1f4065263e1c60a23cacf6b5851144245b8c9.lock.
Script in progress. Can force execution by using --force.
I tried to force, but not success.
If i type su sudo, then run the same command with root:
root@vps10: php /home/domain.com.br/marketing/login/bin/console mautic:segments:update
The script run normally
The ownership and group of: home/domain.com.br/marketing/ is
wwwli8536:wwwli8536
I think there is some mistake on permission of PHP, any information will be very appreciated, thanks in advanced.
