Hi, I am new to Cyberpanel. I need urgent help to correctly configure the Cronjob, it is a system that issues invoices but when migrating it to Cyberpanel the recurring invoicing is not working well, I think it is the URL that I have entered wrong, can you tell me if it is correct?
also try to manually execute the command and output works fine
/usr/local/lsws/lsphp72/bin/php /home/mydomain.com/invoice-ninja/artisan ninja:send-invoices
