I have a problem with setting a cron job via CyberPanel 1.9.4
I set a cron job that runs every minute, exactly like the guide
that echo a string to a file.
echo “run” > /home/domain.com/public_html/log.txt
created the file and gave it 777 permissions.
Through the SSH it runs fine, even used the “su user” command to make sure it has the right permissions.
Now, I can see the cron jobs I created in the path /var/spool/cron/crontabs/user
But what is calling it? Maybe the problem is there and I will be able to trace the problem
Okay I’ve found the problem, when you run “service cron status” you can see the error.
INSECURE MODE (mode 0600 expected) (crontabs/user)
It refuses to run because of wrong permissions
what you need to do is locate the file in /var/spool/cron/crontabs/user
then set chmod to 600
then it will run fine.
another problem is that if you have 2 crons and you remove one of them, everything will be deleted
I am also having an issue… Tried different commands eg “php -q /home/{domain}/public_html/CronTest.php run”
Noticed when logging on Terminal opened the “home” directory, I can see the domain folder. When trying to open the domain folder it says “permission denied”.
