can someone help me, how to solve the above problem. so that my auto update on WordPress can run. please help me. thank you
Can you please share the cron that you can see in your corn tab i can check and tell you more.
please reply my message
help me sir ![]()
can you please run this cron on terminal and show me output or just open a ticket
how to open cron job in terminal, and what you need to see. so I can show it to you
litespeed_task_imgoptm_pull is an error that is displayed on my WordPress dashboard, and this error makes the cronjob not run, so automatic updates are also not possible. I beg you sir please help me
please open a ticket i will check and guide you
how do i open a ticket for my problem. do you have to pay for a certain package for cyberpanel support?
open here i will guide you fither
im alredy creating ticket sir, please check
i hope you can help my, and solving my trouble
please i realy need this problem solving
i checked and replied please continue there
this problem is solved
This happened because I activated WAF in CloudFlare and blocked the INDIA region. after I unblocked the error it didn’t occur, and the cronjob ran normally
Thank you sir for helping me
