i have a lot of subdomains, so i need create wildcard to make redirect from all subdomain to main Domain.
you can manually change it to * in listner or apache conf
Can you explain how? Thank you
in step 2 , you can use * for that vhost to match wildcard domain
https://forums.cyberpanel.net/discussion/3555/tutorial-how-to-access-my-site-with-ip-address#latest
Not working ![]()
still not redirect any subdomain to main domain…
you need a rewrite rule to redirect it
apache - htaccess: exluce some domain in RewriteCond - Stack Overflow
sorry, Not working.
with CPanel i can create wildcard and make redirection, with cyberpanel i can create wildcare
what not working ? what was your setting?
Thank you for replay.
in CPanel i can create wildcard as subdomain and create htaccess in it with redirect. and it working
in cyberpanel, i can’t create wildcard as subdomain.
Yes, you can enter whatever subdomain that is, then follow the guide I provided to change it to wildcard
in cyberpanel, i can’t create wildcard as subdomain.Yes, you can enter whatever subdomain that is, then follow the guide I provided to change it to wildcard
in cpanel, i can crate subdomain like “*.sitename.com”, but i cant create it in cyberpanel
Yes, for the time being , you can enter whatever subdomain that is, like abc.domain.com , then follow the guide I provided to change it to wildcard *
i’m so sorry, but how can i change it?
@qtwrk said:
https://forums.cyberpanel.net/discussion/3555/tutorial-how-to-access-my-site-with-ip-address#latestin step 2 , you can use * for that vhost to match wildcard domain
Thank you, Thank you, Thank you, Thank you, Thank you, Thank you, Thank you, Thank you, Thank you, Thank you, Thank you, Thank you, Thank you, Thank you ![]()
it’s working ![]()
i need help also, can you help me ?
